I’m facing really disturbing problems trying to connect my RG255C-GL device since I updated its firmware to RG255CGLABR01A04M4G version.
With factory firmware (RG255CGLABR01A03M4G_01.001.01.001), I was able to connect using ModemManager (QMI) by supporting the device in qmi_wwan and serial option linux drivers:
qmi_wwan:
{QMI_FIXED_INTF(0x2c7c, 0x0316, 3)}, /* Quectel RG355C */
serial_option:
+#define QUECTEL_PRODUCT_RG255C_GL 0x0316
{ USB_DEVICE_AND_INTERFACE_INFO(QUECTEL_VENDOR_ID, QUECTEL_PRODUCT_RG255C_GL, 0xff, 0xff, 0xff),
.driver_info = RSVD(3) | NUMEP2 },
{ USB_DEVICE_AND_INTERFACE_INFO(QUECTEL_VENDOR_ID, QUECTEL_PRODUCT_RG255C_GL, 0xff, 0, 0) },
{ USB_DEVICE_AND_INTERFACE_INFO(QUECTEL_VENDOR_ID, QUECTEL_PRODUCT_RG255C_GL, 0xff, 0xff, 0x30) },
{ USB_DEVICE_AND_INTERFACE_INFO(QUECTEL_VENDOR_ID, QUECTEL_PRODUCT_RG255C_GL, 0xff, 0xff, 0x40) },
and aplying patches suggested by quectel in UMTS_LTE_5G_Linux_USB_Driver_User_Guide v 3.2 document.
My current situation is this:
Device: RG255C-GL
Firmware: RG255CGLABR01A04M4G
Kernel: Linux 5.10.72
ModemManager: v1.22
Platform: i.MX8MP (Yocto-based, aarch64)
ModemManager doesn’t detect cdc-wdm0 port
ports: ttyUSB2 (at), wwan0 (ignored)
plugin: quectel
and qmi commands fail with
CID allocation failed in the CTL client: Transaction timed out
error log
I have tried several things such as patching linux driver to export QMI protocol as 0x51 (current shows 0x50):
usb-devices | grep -A10 2c7c
P: Vendor=2c7c ProdID=0316 Rev=05.15
S: Manufacturer=Quectel
S: Product=RG255C-GL
S: SerialNumber=590b3526
C: #Ifs= 4 Cfg#= 1 Atr=a0 MxPwr=500mA
I: If#=0x0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=30 Driver=option
I: If#=0x1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
I: If#=0x2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=40 Driver=option
I: If#=0x3 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=50 Driver=qmi_wwan
Tried with quectel custom driver (qmi_wwan_q) v1.2.7 as suggested in firmware release notes and same effect.
Tried to connect in ECM mode also failed even after Modem has public IP.
So my questions are:
- Does firmware version
RG255CGLABR01A04M4Gfully support QMI (usbnet=0)? - Is there a required AT command to activate the QMI service stack or data plane?
- Are there any firmware constraints preventing QMI access or CID allocation?
- Can you provide a known-working firmware version for QMI under Linux?
- Is a custom initialization sequence needed (e.g.
AT+QMAP,AT+QMIWDS)?
Thank you for your help
