In my project, I am using an ESP32-S3 and a Quectel EG-915U-EU modem connected to the ESP32-S3 via D+ and D-. To work with the modem, I am using the iot_usbh_modem component. The problem is that the connection with the modem periodically drops.
The modem is powered from a separate power supply, and the ESP32-S3 is also powered separately. There don’t seem to be any power issues. Has anyone encountered this problem and can suggest a solution?
(23082624) DISPLAY: WiFi update: enabled=1, connected=0, rssi=-100, ssid=‘’, internet_up=0
I (23082624) DISPLAY: WiFi display: ON (waiting for connection)
I (23082634) DISPLAY: WiFi EVENT: connected=0, rssi=-100, ssid=‘’
I (23085014) DISPLAY: WiFi update: enabled=1, connected=0, rssi=-100, ssid=‘’, internet_up=0
I (23085014) WIFI: WiFi disconnected. Retrying…
I (23085014) DISPLAY: WiFi display: ON (waiting for connection)
I (23085024) DISPLAY: WIFI INTERNET: DOWN (red)
I (23085034) DISPLAY: WiFi update: enabled=1, connected=0, rssi=-100, ssid=‘’, internet_up=0
I (23085034) DISPLAY: WiFi display: ON (waiting for connection)
I (23085044) DISPLAY: WiFi EVENT: connected=0, rssi=-100, ssid=‘’
W (23086044) MAIN: ===================================================================================
I (23086064) MAIN: GSM rssi=21, ber=99
I (23086064) MAIN: ******** IP address of google.com: 142.251.36.78
I (23086074) MAIN: Ping addr 8.8.8.8 Restart..
I (23086204) MAIN: 64 bytes from 8.8.8.8 icmp_seq=1 ttl=114 time=128 ms
E (23086234) USBH_CDC: RX xfer failed, status 1
E (23086234) USB HOST: EP command error: ESP_ERR_INVALID_STATE
E (23086244) USB HOST: EP command error: ESP_ERR_INVALID_STATE
E (23086254) USB HOST: EP command error: ESP_ERR_INVALID_STATE
E (23086264) USB HOST: EP command error: ESP_ERR_INVALID_STATE
E (23086274) USB HOST: EP command error: ESP_ERR_INVALID_STATE
I (23086294) modem_board: Modem state STAGE_DTE_LOSS, Start
W (23086294) esp-modem: Waiting exit the PPP mode gracefully
I (23086294) modem_board: Modem state STAGE_DTE_LOSS, Success!
E (23086304) USBH_CDC: usbh_cdc_write_bytes(1005): Device is not connected
E (23086304) esp-tls-mbedtls: read error :-0x004C
E (23086314) transport_base: esp_tls_conn_read error, errno=Software caused connection abort
E (23086324) mqtt_client: esp_mqtt_handle_transport_read_error: transport_read() error: errno=113
E (23086334) MQTT_APP: MQTT error: 1
E (23086334) mqtt_client: mqtt_process_receive: mqtt_message_receive() returned -2
I (23086344) MQTT_APP: MQTT_EVENT_DISCONNECTED
I (23087424) WIFI: WiFi disconnected. Retrying…
I (23087424) DISPLAY: WiFi update: enabled=1, connected=0, rssi=-100, ssid=‘’, internet_up=0
I (23087424) DISPLAY: WiFi display: ON (waiting for connection)
I (23087434) DISPLAY: WIFI INTERNET: DOWN (red)
I (23087454) DISPLAY: WiFi update: enabled=1, connected=0, rssi=-100, ssid=‘’, internet_up=0
I (23087454) DISPLAY: WiFi display: ON (waiting for connection)
I (23087464) DISPLAY: WiFi EVENT: connected=0, rssi=-100, ssid=‘’
E (23087554) ENUM: LANGID 0x409 not found
Found IN endpoint: 138
Found OUT endpoint: 7
Found NOTIF endpoint: 137
I (23087554) USBH_CDC: Opened cdc device: 14
Found IN endpoint: 132
Found OUT endpoint: 2
Found NOTIF endpoint: 131
*** Device descriptor ***
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0x0
bDeviceSubClass 0x0
bDeviceProtocol 0x0
bMaxPacketSize0 64
idVendor 0x2c7c
idProduct 0x901
bcdDevice 3.10
iManufacturer 1
iProduct 2
iSerialNumber 3
bNumConfigurations 1
*** Configuration descriptor ***
bLength 9
bDescriptorType 2
wTotalLength 263
bNumInterfaces 9
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
bMaxPower 400mA
*** Interface Association Descriptor ***
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 2
bFunctionClass 0x2
bFunctionSubClass 0x6
bFunctionProtocol 0x0
iFunction 4
*** Interface descriptor ***
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 0x2
bInterfaceSubClass 0x6
bInterfaceProtocol 0x0
iInterface 6
*** Endpoint descriptor ***
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 0x3 INT
wMaxPacketSize 16
bInterval 32
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
bInterfaceClass 0xa
bInterfaceSubClass 0x0
iInterface 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 2
bInterfaceClass 0xa
iInterface 5
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 0x2 BULK
wMaxPacketSize 64
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x1 EP 1 OUT
wMaxPacketSize 64
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 3
bInterfaceClass 0xff
iInterface 8
bLength 7
bDescriptorType 5
bEndpointAddress 0x84 EP 4 IN
wMaxPacketSize 64
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x2 EP 2 OUT
wMaxPacketSize 64
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
wMaxPacketSize 64
bInterval 32
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 2
iInterface 8
bLength 7
bDescriptorType 5
bEndpointAddress 0x85 EP 5 IN
wMaxPacketSize 64
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x3 EP 3 OUT
wMaxPacketSize 64
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 4
bAlternateSetting 0
bNumEndpoints 2
iInterface 8
bLength 7
bDescriptorType 5
bEndpointAddress 0x86 EP 6 IN
wMaxPacketSize 64
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x4 EP 4 OUT
wMaxPacketSize 64
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 5
bAlternateSetting 0
bNumEndpoints 2
iInterface 8
bLength 7
bDescriptorType 5
bEndpointAddress 0x87 EP 7 IN
wMaxPacketSize 64
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x5 EP 5 OUT
wMaxPacketSize 64
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 6
bAlternateSetting 0
bNumEndpoints 2
iInterface 8
bLength 7
bDescriptorType 5
bEndpointAddress 0x88 EP 8 IN
wMaxPacketSize 64
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x6 EP 6 OUT
wMaxPacketSize 64
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 7
bAlternateSetting 0
bNumEndpoints 3
iInterface 8
bLength 7
bDescriptorType 5
bEndpointAddress 0x8a EP 10 IN
wMaxPacketSize 64
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x7 EP 7 OUT
wMaxPacketSize 64
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x89 EP 9 IN
wMaxPacketSize 64
bInterval 32
bLength 9
bDescriptorType 4
bInterfaceNumber 8
bAlternateSetting 0
bNumEndpoints 2
iInterface 8
bLength 7
bDescriptorType 5
bEndpointAddress 0x8b EP 11 IN
wMaxPacketSize 64
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x8 EP 8 OUT
wMaxPacketSize 64
bInterval 0
I (23088064) modem_board: DTE reconnect, reconnecting …
I (23088064) USBH_CDC: Opened cdc device: 14
I (23088074) USBH_CDC: New device connected, address: 14
I (23088074) MAIN: Task dump
I (23088084) MAIN: Load Stack left Name PRI
I (23088094) MAIN: nan 636 modem_daemon 6
I (23088094) MAIN: nan 9516 display_task 5
I (23088104) MAIN: nan 320 main 1
I (23088104) MAIN: nan 696 IDLE0 0
I (23088114) MAIN: nan 688 IDLE1 0
I (23088114) MAIN: nan 1992 tiT 18
I (23088124) MAIN: nan 408 mqtt_inet_evt 5
I (23088124) MAIN: nan 4124 system_events 5
I (23088134) MAIN: nan 1780 ping 2
I (23088134) MAIN: nan 888 mqtt_task 5
I (23088144) MAIN: nan 996 usb_data_recv 6
I (23088144) MAIN: nan 536 ipc0 24
I (23088154) MAIN: nan 1904 usb_lib 5
I (23088154) MAIN: nan 2968 esp_timer 22
I (23088164) MAIN: nan 1252 wifi 23
I (23088164) MAIN: nan 368 sys_evt 20
I (23088174) MAIN: nan 1620 usbh_cdc 5
I (23088174) MAIN: nan 1320 Tmr Svc 1
I (23088184) MAIN: nan 528 ipc1 24
I (23088184) MAIN: Free heap=8498092 Free mini=8257536 bigst=8445756, internal=127064 bigst=77824
I (23089074) modem_board: reconnect after 2s…
I (23089824) WIFI: WiFi disconnected. Retrying…
I (23089834) DISPLAY: WiFi update: enabled=1, connected=0, rssi=-100, ssid=‘’, internet_up=0
I (23089834) DISPLAY: WiFi display: ON (waiting for connection)
I (23089834) DISPLAY: WIFI INTERNET: DOWN (red)
I (23089854) DISPLAY: WiFi update: enabled=1, connected=0, rssi=-100, ssid=‘’, internet_up=0
I (23089854) DISPLAY: WiFi display: ON (waiting for connection)
I (23089864) DISPLAY: WiFi EVENT: connected=0, rssi=-100, ssid=‘’
I (23090074) modem_board: reconnect after 1s…
I (23090074) modem_board: Modem state STAGE_SYNC, Start
I (23090214) modem_board: Network Auto reconnecting …
I (23090214) modem_board: Modem state STAGE_SYNC, Success!
I (23090314) modem_board: Modem state STAGE_SET_URC, Start
I (23090414) modem_board: URC port set to “usbmodem” successfully
I (23090414) modem_board: Modem state STAGE_SET_URC, Success!
I (23090514) modem_board: Modem state STAGE_SET_APN_DEFAULT, Start
W (23090614) esp_modem_dce: esp_modem_dce_generic_command(31): Command:AT+CGDCONT=1,“IP”,“”
…failed
W (23090614) modem_board: Failed to send APN clear command
W (23090614) modem_board: Modem state STAGE_SET_APN_DEFAULT, Failed, retry1, after 3000ms…
I (23092234) WIFI: WiFi disconnected. Retrying…
I (23092244) DISPLAY: WiFi update: enabled=1, connected=0, rssi=-100, ssid=‘’, internet_up=0
I (23092244) DISPLAY: WiFi display: ON (waiting for connection)
I (23092244) DISPLAY: WIFI INTERNET: DOWN (red)
I (23092264) DISPLAY: WiFi update: enabled=1, connected=0, rssi=-100, ssid=‘’, internet_up=0
I (23092264) DISPLAY: WiFi display: ON (waiting for connection)
I (23092274) DISPLAY: WiFi EVENT: connected=0, rssi=-100, ssid=‘’
I (23092334) esp-netif_lwip-ppp: ppp: User interrupt
I (23092334) esp-modem-netif: PPP state changed event 5: (NETIF_PPP_ERRORUSER)
I (23093624) modem_board: Modem state STAGE_SET_APN_DEFAULT, Start
I (23093704) modem_board: APN cleared successfully
I (23093704) modem_board: Modem state STAGE_SET_APN_DEFAULT, Success!
I (23093804) modem_board: Modem state STAGE_CHECK_SIM, Start
I (23093904) modem_board: SIM Card Ready
I (23093904) modem_board: Modem state STAGE_CHECK_SIM, Success!
I (23094004) modem_board: Modem state STAGE_CHECK_SIGNAL, Start
I (23094644) DISPLAY: WiFi update: enabled=1, connected=0, rssi=-100, ssid=‘’, internet_up=0
I (23094644) WIFI: WiFi disconnected. Retrying…
I (23094644) DISPLAY: WiFi display: ON (waiting for connection)
I (23094654) DISPLAY: WIFI INTERNET: DOWN (red)
I (23094664) DISPLAY: WiFi update: enabled=1, connected=0, rssi=-100, ssid=‘’, internet_up=0
I (23094664) DISPLAY: WiFi display: ON (waiting for connection)
I (23094674) DISPLAY: WiFi EVENT: connected=0, rssi=-100, ssid=‘’
I (23096104) modem_board: Signal quality: rssi=21, ber=99
I (23096104) modem_board: Modem state STAGE_CHECK_SIGNAL, Success!
I (23096204) modem_board: Modem state STAGE_CHECK_REGIST, Start
