Problem to connect to EMQX Public Broker via SSL (BG95)
I try to connect my BG95 Modul with the public emqx boker. I tried it without ssl first und that worked. Now I want to use ssl. I tried it with the following commands:
ati
BG95-M3
Revision: BG95M3LAR02A04
at+cgreg?;+creg?;+cereg?;+qnwinfo
+CGREG: 0,5
+CREG: 0,5
+CEREG: 0,4
+QNWINFO: “EDGE”,“26202”,“GSM 900”,2
AT+QFUPL=“emqx.pem”,1338,100
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
at+qflst=“UFS:*”
+QFLST: “emqx.pem”,1338
+QFLST: “security/”,2
AT+CGDCONT?
+CGDCONT: 3,“IP”,“[vodafone-APN]”,“0.0.0.0”,0,0,0
AT+CGACT=1,3
AT+CGACT?
+CGACT: 1,0
+CGACT: 2,0
+CGACT: 3,1
AT+QSSLCFG=“cacert”,2,“UFS:emqx.pem”
AT+QSSLCFG=“seclevel”,2,1
AT+QSSLCFG=“sslversion”,2,4
AT+QMTCFG=“ssl”,0,1,2
AT+QMTCFG=“pdpcid”,0,3
AT+QMTCFG=“version”,0,4
AT+QMTOPEN=0,“broker.emqx.io”,8883
+QMTOPEN: 0,-1
Does anyone can see what might be the problem here
Hey, I am having the same issue.
What their support told me was to use “SNI”, but that didn’t help.
This is my approach:
I want to connect to the emqx broker with the Quectel Bg950 via AT commands.
I receive a correct connection via AT+QMTOPEN, but AT+QMTCONN fails.
Doing a different approach with mosquitto is working (of course using with the certificate).
This is my reponse log:
Received: AT OK
Module is ready.
Sent: AT+QFLST
Received:
AT+QFLST
+QFLST: “cacert.pem”,1339
+QFLST: “security/”,0
File ‘cacert.pem’ exists with size 1339 bytes.
Sent:
AT+QSSLCFG=“cacert”,2,“cacert.pem”
Received:
Sent:
Received:
Sent:
Received: AT+QSSLCFG=“sslversion”,2,4
Sent: AT+QSSLCFG=“ciphersuite”,2,0XFFFF
Received:
Sent: AT+QSSLCFG=“session”,2,1
Received:
Sent: AT+QSSLCFG=“ignorelocaltime”,2,1
Received:
Sent: AT+QSSLCFG=“sni”,2,1
Received:
SSL configuration for context 2 completed successfully.
Sent: AT+QICFG=“tcp/keepalive”,1,120,25,10
Received:
TCP configuration completed successfully.
Sent: AT+QMTCFG=“ssl”,1,1,2
Received:
Sent: AT+QMTCFG=“version”,1,4
Received:
Sent: AT+QMTCFG=“keepalive”,1,300
Received:
Sent: AT+QMTCFG=“session”,1,1
Received:
MQTT configuration for client ID 1 completed successfully.
Sent: AT+QMTOPEN=1,“xxxxxxxx.ala.eu-central-1.emqxsl com”,8883
Received:
+QMTOPEN: 1,0
MQTT connection started.
Sent: AT+QMTCONN=1,“bg_battery”,“battery”,“battery”
Received:
+QMTCONN: 1,0,5
+QMTSTAT: 1,4
Failed to connect MQTT client.
So my setup is working when using EMQX Dedicated instead of Serverless.
It seems that the SNI makes some problems for the BG950?
I figured it out for my specific case. But I changed from EMQX to the broker of my SIM-Card Provider (Vodafone)
First of all, I used the wrong Root Certificate. I found the right one with the openssl command (openssl s_client -connect [boker-URL]:8883 -showcerts)
But I also needed to set the parameter AT+QSSLCFG=“ignorelocaltime”,2,0 to “Does not ignore validity check for certificate” and had o enable Server Name Identification (AT+QSSLCFG=“sni”,2,1).
Now I can connect to the vodafone mqtt boker.
This is awesome! Changing the ignorelocaltime to false (0) did solve the issue. Also what seems to be necessary to add some padding size when uploading the certificate. I used strlen(certificate) + 15 as the filesize.
