PPS duration for LC29HBANR11A05S_CS2?
Hello, in my application I need a PPS signal duration of 10msec as opposed to the 100msec default. Is there a command available on the LC29HBA to achieve that?
Thank you!!
Vincenzo
Prova a vedere in par.2.3.25
2.3.150 … 2.3.154 PAIR_PPS command
It worked!!! Thanks a million!!!
Vincenzo
While I can change the duration of the PPS pulse, I can’t seem to find a way to change the frequency of the PPS from 1 sec to some other arbitrary number like 2Hz etc. Is there a command for that or are we stuck with 1PPS? Is it the PAIR750 and the Local_ms really means the time pulse period?
Thanks!
