Only seeing DM/NMEA ports
Do I need a specific driver version (Windows 11)? This is after switching the “usbnet” to 1 to attempt using QMI.
Which module is it?
I guess that you have set the modem to RNDIS mode.
Hi it’s the RM520N-GL.
Which Quectel driver you have tried?
Please check
AT+QCFG=“usbnet”
AT+QCFG=“data_interface”
I don’t have access to AT commands anymore, as mentioned.
Last commands I ran to set the values you are asking are:
AT+QCFG="data_interface",0,0
AT+QCFG="usbnet",1
I have all three drivers installed by the way.
  • ECM 1.0
  • MBIM 1.3
  • NDIS 2.4 (tried 2.7)
  • RNDIS 1.1 (tried 1.0)
Please do not try the RNDIS driver.
You can use the MBIM driver and set the modem to MBIM mode with
AT+QCFG=“usbnet”,2
If you cannot send the AT on this Win11, you can try it on Ubuntu PC.
Thank you! I removed the RNDIS driver and that worked.
I have another issue now, I am trying to follow this guide to get a standalone modem working with the same SIM card as a working GLi.Net Spitz X3000 (same RM520N-GL modem).
So far I have done the following to match them up to the same parameters but the modem is not registering onto the network as AT+CEER returns EMM detached and I see +QLWURC: "deregister", 0 after a period of time.
ATI
Quectel
RM520N-GL
RM520NGLAAR03A03M4G
(matches X3000)
AT+QCFG="usbnet"
+QCFG="usbnet",0
(matches X3000)
AT+CGDCONT?
+CGDCONT: 1,"IPV4V6","ims","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0,,,,,,,,,"",,,,0
+CGDCONT: 2,"IPV4V6","vzwadmin","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0,,,,,,,,,"",,,,0
+CGDCONT: 3,"IPV4V6","VZWINTERNET","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0,,,,,,,,,"",,,,0
+CGDCONT: 4,"IPV4V6","vzwapp","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0,,,,,,,,,"",,,,0
+CGDCONT: 5,"IPV4V6","vzwemergency","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,1,,,,,,,,,"",,,,0
+CGDCONT: 6,"IPV4V6","vzwclass6","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0,,,,,,,,,"",,,,0
+CGDCONT: 7,"IPV4V6","vzwiotts","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0,,,,,,,,,"",,,,0
(matches X3000)
AT+QMBNCFG="List"
+QMBNCFG: "List",0,1,1,"CDMAless-Verizon",0x0A010126,202304251
(matches X3000)
AT+GSN
[IMEI redacted]
(compatible with carrier)
AT+CIMI
[IMSI redacted]
(matches X3000)
Anything else to check?
There was a similar situation. The modem was also not registered on the network. The at+cfun=1 command helped me
I’ll try that again, thanks for your response. I also tried a factory reset AT&F, what carrier are you using?
p.s. I found a few more commands here I’ll try…
https://forums.quectel.com/t/bg96-at-command-to-reset-non-volatile-settings-to-default/3358/3
I’m from Russia, so our operators are definitely different and you haven’t even heard of him) Did this at command help you, or is registration still not going through?
I found out yesterday that the modem is working properly via the “usbnet” as I can use the connection via my laptop but it seems the “pcie/mode”/modem isn’t connecting on it’s own.
I currently have it configured as described here RM520N-GL - PCIe to Ethernet... (and DHCP!) - #7 by spacesuitdiver
+QCFG="data_interface",1,0
AT+QCFG="usbnet"
+QCFG: "usbnet",2 (TE)
AT+QCFG="pcie/mode"
+QCFG: "pcie/mode",1 (AP)
AT+QETH="eth_driver"
+QETH: "eth_driver","r8125",1
