Need latest firmware for L89-s90
i need latest firmware for L89-S90 module, used in country INDIA
Hi
What is your current firmware version? Much appreciation.
$PSTMVER,GNSSLIB_8.4.14.21_ARM43
$GPTXT,L89NR01A06V01
23
$PSTMVER,OS20LIB_4.3.0_ARM47
$PSTMVER,GPSAPP_2.8.4_ARM
12
$PSTMVER,BINIMG_4.5.12.4_ARM37
$PSTMVER,SWCFG_81065329
6C
$PSTMVER,STAGPSLIB_6.0.0_ARM5A
$PSTMVER,STA8090_622bc043
6F
$GPTXT,(C)2000-2018 ST Microelectronics29
23
$PSTMSWCONFIG,1,0,12,0001050105070a0a0e0d0c0b0a090608070203630a110c04110c0155030130500f00000f0714000affffffffffffffffffffffffffffffffffffffffffffffff47
$PSTMSWCONFIG,1,1,12,ffffffffffffffffffffffffffffffffffffffffffffffffffff010101000001094005ffffffffff4c9641095600180000000000000000000000000050000000
44
$PSTMSWCONFIG,1,2,12,ffffffff00000000ffffffff000000000000000000000000ffffffff000000000000000000000000fffffffffffffffffffffffffffffffff090c02b0528200045
$PSTMSWCONFIG,1,3,12,01323200050358020a0a0000fe0300001690813e0d0000bc1000c27e0000000000000000000000000000000000000000000000000000000000000000ac07730d
4E
$PSTMSWCONFIG,1,4,12,120000009a106464ae61840000000100ff0a0b0019000000010101000000000006000000ffffffff040000000100000000000080b004780503000000f0c3f7ff4F
$PSTMSWCONFIG,1,5,12,00000000ffffffff000000000c0a00020fb4a005f5a30000010a1900330a0a1400510000800e000000001810000008000e01000000000000020f000000000000
42
$PSTMSWCONFIG,1,6,12,0000e803ffffffff00000000ffffffff4810c703ffffffff9abed2e6edf2fafb00000202050601011d11ff000e010f01ff00ff000403ff0000000000000000004A
$PSTMSWCONFIG,1,7,12,000000000000e03f0000000000000000000000000000f03fd3872ea86f754440938c9c853d8d2c403db83b6bb71b56404b0484b86d3da53e0cb8df888b2f9c3e
49
$PSTMSWCONFIG,1,8,12,2b69a4292b1b503e0cb8df888b2f9c3e4b0484b86d3da53e000000000000000000000000000000005feffe78af8e44406c21c84109c32b40000000000000244040
$PSTMSWCONFIG,1,9,12,1d8f19a88c8f4440598b4f0130be2b4000000000000024407ac2120f289f44402315c616828c2b400000000000002440ace28dcc239f444095826e2f698c2b40
12
$PSTMSWCONFIG,1,10,12,00000000000024400f0c0c120f0c0c120f0c0c120f0c0c124c38394e52303141303656303100000000000000000000000000000000000000000000000000000025
$PSTMSWCONFIG,1,11,12,0000000000000000000000000000000000000000000000000000000000000000
26
$GPRMC,102222.320,V,5130.05587,N,00007.48076,W,210627,N*66
output on boot, also i need command list right now i am unable to get response for any command not sure why. thanks.
The FW has been sent to your email.
BR,
June
thanks for sharing the FW.
I need few info of this module.
  1. does this module support I2C interface. am trying to change it with `$PSTMCFGPORT,1,0,0x3A,0 command its not changing.
  2. what are the set of commands to put module in complete standbymode i.e(sleep mode). with $PSTMFORCESTANDBY command its still drawing around 87mA of current.
note: other command are working fine.
thanks again.
regards
thousif
