Akhil
June 9, 2025, 6:58am
1
Hai
I am trying to connect and send data using MQTT. When using the open-source broker (broker.emqx.io
on port 8883
), the connection is successful, and I am able to publish data. However, when using the dedicated server (rb4d38e0.ala.asia-southeast1.emqxsl.com
on port 8883
), the connection is established, but publishing does not work
Am i missing something,
Thanks in advance.
Could you provide the version of the modem you are using and the detailed AT log?
AT+QGMR
Akhil
June 9, 2025, 7:24am
3
@herbert.pan-Q : EG800AKCN90LCR07A05M02
Could you provide the detailed AT log?
Akhil
June 10, 2025, 10:41am
5
@herbert.pan-Q :
[2025-06-10_16:06:43:305]AT+QMTCFG=“SSL”,1,1,2
[2025-06-10_16:06:43:305]OK
[2025-06-10_16:06:44:800]AT+QMTCFG=“keepalive”,1,3600
[2025-06-10_16:06:44:800]OK
[2025-06-10_16:06:47:159]OPEN COMMAND---->
[2025-06-10_16:06:47:680]
[2025-06-10_16:06:47:680]+QMTOPEN: 1,0
[2025-06-10_16:06:53:031]CONNECT COMMAND---->
[2025-06-10_16:06:53:189]+QMTCONN: 1,0,5
[2025-06-10_16:06:53:189]+QMTSTAT: 1,4
Please refer to the AT log.
Note: I am not supposed to send the credentials in a public forum.
I expect that you can send the CA certificate and the AT logs you executed to my email herbert.pan@quectel.com ;
Akhil
June 12, 2025, 4:10am
7
@herbert.pan-Q
Please check the mail I have sent you the AT logs in mail.
If there is no CA certificate, please perform the following Setting
AT+QMTCFG=“SSL”,1,1,0
Akhil
June 12, 2025, 6:05am
9
@herbert.pan-Q :
Still the same issue occurs,
But with different server there is no issue arising.
Could you output all the AT logs you have executed?
