I am using MC60_OpenCPU_GS3_SDK_V1.6 SDK to develop MQTT client, but there is no example code for using MQTT protocol (inside cloud\protocol\mqtt APIs). Can anyone please help with MQTT sample example for MC60?
Thanks!
Thanks!
Hi @trakbond
kindly use this below example
Set "C_PREDEF=-D __EXAMPLE_TCPSSL__" in gcc_makefile file. And compile the
app using "make clean/new".
Download image bin to module to run.
HISTORY
#ifdef EXAMPLE_MQTT
#include “ql_stdlib.h”
#include “ql_common.h”
#include “ql_type.h”
#include “ql_trace.h”
#include “ql_error.h”
#include “ql_uart.h”
#include “ql_gprs.h”
#include “ql_timer.h”
#include “ril_network.h”
#include “ril.h”
#include “ril_util.h”
#include “ril_system.h”
#define DEBUG_ENABLE 1
#if DEBUG_ENABLE > 0
#define DEBUG_PORT UART_PORT1
#define DBG_BUF_LEN 512
static char DBG_BUFFER[DBG_BUF_LEN];
#define APP_DEBUG(FORMAT,…) {
Ql_memset(DBG_BUFFER, 0, DBG_BUF_LEN);
Ql_sprintf(DBG_BUFFER,FORMAT,##VA_ARGS);
if (UART_PORT2 == (DEBUG_PORT))
Ql_Debug_Trace(DBG_BUFFER);
} else {
Ql_UART_Write((Enum_SerialPort)(DEBUG_PORT), (u8*)(DBG_BUFFER), Ql_strlen((const char *)(DBG_BUFFER)));
#else
#endif
typedef struct{
u8 index;
u8* prefix;
s32 data;
u32 length;
}MQTT_Param;
static s32 timeout_90S_monitor = FALSE;
#define MAX_MQTT_PARAM_LENGTH 100
// #define HOST_NAME “iot-as-mqtt.cn-shanghai.aliyuncs.com”
#define HOST_NAME “test.mosquitto.org”
#define HOST_PORT 1883
#define CONTEXT 0
static u8 product_key[MAX_MQTT_PARAM_LENGTH] = “142”;
static u8 device_name[MAX_MQTT_PARAM_LENGTH] = “TEST1”;
static u8 device_secret[MAX_MQTT_PARAM_LENGTH] = “lN9l09QesoiL4HXw7W9Z1XVJ0JzTJxhs”;
static u8 topic_update[MAX_MQTT_PARAM_LENGTH] = “adpp”;
// static u8 topic_update[MAX_MQTT_PARAM_LENGTH] = “/hDTjzV2bVeR/TEST1/update”;
static u8 topic_error[MAX_MQTT_PARAM_LENGTH] = “/hDTjzV2bVeR/TEST1/update/error”;
static u8 topic_get[MAX_MQTT_PARAM_LENGTH] = “/hDTjzV2bVeR/TEST1/get”;
u8 test_message[50] = “allan\0”;
typedef enum{
STATE_NW_GET_SIMSTATE,
STATE_NW_QUERY_STATE,
STATE_GPRS_CONTEXT,
STATE_GPRS_ACTIVATE,
STATE_MQTT_CFG,
STATE_MQTT_OPEN,
STATE_MQTT_CONN,
STATE_MQTT_SUB_1,
STATE_MQTT_SUB_2,
STATE_MQTT_PUB,
STATE_MQTT_CLOSE,
STATE_GPRS_DEACTIVATE,
STATE_TOTAL_NUM,
NULL_STATE
}Enum_TCPSTATE;
static u8 m_tcp_state = STATE_NW_GET_SIMSTATE;
static MQTT_Param mqtt_param;
static s32 ATResponse_mqtt_handler(char* line, u32 len, void* userdata);
static s32 ATResponse_mqtt_handler_pub(char* line, u32 len, void* userdata);
static s32 ATResponse_mqtt_handler_close(char* line, u32 len, void* userdata);
static void Hdlr_Mqtt_Recv_Data(u8* packet);
static void Hdlr_Mqtt_Recv_State(u8* packet);
s32 RIL_MQTT_QMTCFG_Ali( u8 connectID,u8* product_key,u8* device_name,u8* device_secret);
s32 RIL_MQTT_QMTOPEN( u8 connectID,u8* hostName, u32 port );
s32 RIL_MQTT_QMTCONN(u8 connectID, u8* clientID,u8* username,u8* password);
s32 RIL_MQTT_QMTSUB(u8 connectID, u8 msgId,u8* topic, u8 qos,u8* others);
s32 RIL_MQTT_QMTPUB(u8 connectID, u8 msgId,u8 qos,u8 retain, u8* topic,u8* data,u8 length);
s32 RIL_MQTT_QMTDISC(u8 connectID);
s32 RIL_MQTT_QMTCLOSE(u8 connectID);
s32 RIL_MQTT_QMTUNS(u8 connectID, u8 msgId,u8* topic,u8* others);
void proc_main_task(s32 taskId)
s32 ret;
ST_MSG msg;
// Register & open UART port
Ql_UART_Register(UART_PORT1, CallBack_UART_Hdlr, NULL);
Ql_UART_Open(UART_PORT1, 115200, FC_NONE);
APP_DEBUG("<--OpenCPU: mqtt test.-->\r\n");
Ql_Timer_Register(MQTT_TIMER_ID, Callback_Timer, NULL);
Ql_Timer_Start(MQTT_TIMER_ID, MQTT_TIMER_PERIOD, TRUE);
Ql_Timer_Register(TIMEOUT_90S_TIMER_ID, Callback_Timer, NULL);
while(TRUE)
Ql_OS_GetMessage(&msg);
switch(msg.message)
case MSG_ID_RIL_READY:
APP_DEBUG("<-- RIL is ready -->\r\n");
Ql_RIL_Initialize();
break;
case MSG_ID_URC_INDICATION:
switch (msg.param1)
case URC_MQTT_RECV_IND:
APP_DEBUG("<-- RECV DATA:%s -->\r\n", msg.param2);
Hdlr_Mqtt_Recv_Data(msg.param2);
break;
case URC_MQTT_STAT_IND:
APP_DEBUG("<-- RECV STAT:%s-->\r\n", msg.param2);
Hdlr_Mqtt_Recv_State(msg.param2);
break;
break;
default:
break;
//src_string=“GPRMC,235945.799,V,0.00,0.00,050180,N” index =1 ·µ»ØTRUE ,dest_string=“235945.799”; index =3£¬·µ»ØFALSE
char QSDK_Get_Str(char *src_string, char *dest_string, unsigned char index)
char SentenceCnt = 0;
char ItemSum = 0;
char ItemLen = 0, Idx = 0;
char len = 0;
unsigned int i = 0;
if (src_string ==NULL)
return FALSE;
len = Ql_strlen(src_string);
for ( i = 0; i < len; i++)
if (*(src_string + i) == ',')
ItemLen = i - ItemSum - SentenceCnt;
ItemSum += ItemLen;
if (index == SentenceCnt )
if (ItemLen == 0)
return FALSE;
else
Ql_memcpy(dest_string, src_string + Idx, ItemLen);
*(dest_string + ItemLen) = '\0';
return TRUE;
SentenceCnt++;
Idx = i + 1;
if (index == SentenceCnt && (len - Idx) != 0)
Ql_memcpy(dest_string, src_string + Idx, len - Idx);
*(dest_string + len) = '\0';
return TRUE;
else
return FALSE;
u8 mqtt_message[1024]={0};
QSDK_Get_Str(packet,mqtt_message,3);
APP_DEBUG("<-- RECV message:%s–>\r\n",mqtt_message);
char strTmp[10];
Ql_memset(strTmp, 0x0, sizeof(strTmp));
QSDK_Get_Str(packet,strTmp,3);
APP_DEBUG("<-- mqtt state = %d-->\r\n",Ql_atoi(strTmp));
static void CallBack_UART_Hdlr(Enum_SerialPort port, Enum_UARTEventType msg, bool level, void* customizedPara)
static void Callback_Timer(u32 timerId, void* param)
s32 ret ;
if (MQTT_TIMER_ID == timerId)
switch(m_tcp_state)
case NULL_STATE:
break;
case STATE_NW_GET_SIMSTATE:
s32 simStat = 0;
RIL_SIM_GetSimState(&simStat);
if (simStat == SIM_STAT_READY)
m_tcp_state = STATE_NW_QUERY_STATE;
APP_DEBUG("<--SIM card status is normal!-->\r\n");
}else
APP_DEBUG("<--SIM card status is unnormal!-->\r\n");
break;
case STATE_NW_QUERY_STATE:
s32 creg = 0;
s32 cgreg = 0;
ret = RIL_NW_GetGSMState(&creg);
ret = RIL_NW_GetGPRSState(&cgreg);
APP_DEBUG("<--Network State:creg=%d,cgreg=%d-->\r\n",creg,cgreg);
if((cgreg == NW_STAT_REGISTERED)||(cgreg == NW_STAT_REGISTERED_ROAMING))
m_tcp_state = STATE_GPRS_CONTEXT;
break;
case STATE_GPRS_CONTEXT:
ret = RIL_NW_SetGPRSContext(CONTEXT);
APP_DEBUG("<-- Set GPRS context, ret=%d -->\r\n", ret);
if(ret ==0)
m_tcp_state = STATE_GPRS_ACTIVATE;
break;
case STATE_GPRS_ACTIVATE:
ret = RIL_NW_SetAPN(1, m_apn, m_userid, m_passwd);
APP_DEBUG("<-- Set GPRS APN, ret=%d -->\r\n", ret);
ret = RIL_NW_OpenPDPContext();
APP_DEBUG("<-- Open PDP context, ret=%d -->\r\n", ret);
if(ret ==0)
// m_tcp_state = STATE_MQTT_OPEN;
m_tcp_state = STATE_MQTT_CFG;
break;
case STATE_MQTT_CFG:
ret = RIL_MQTT_QMTCFG_Ali( 0,product_key,device_name, device_secret);
APP_DEBUG("<-- mqtt config, ret=%d -->\r\n", ret);
if(ret ==0)
break;
case STATE_MQTT_OPEN:
ret = RIL_MQTT_QMTOPEN( 0,HOST_NAME, HOST_PORT) ;
APP_DEBUG("<-- mqtt open, ret=%d -->\r\n",ret);
if(ret ==0)
m_tcp_state = STATE_MQTT_CONN;
else
m_tcp_state = STATE_GPRS_DEACTIVATE;
break;
case STATE_MQTT_CONN:
char strImei[30];
Ql_memset(strImei, 0x0, sizeof(strImei));
ret = RIL_GetIMEI(strImei);
APP_DEBUG("<-- IMEI:%s,ret=%d -->\r\n", strImei,ret);
ret = RIL_MQTT_QMTCONN(0,strImei,NULL,NULL);
APP_DEBUG("<-- mqtt connect,ret=%d -->\r\n", ret);
if(ret ==0)
m_tcp_state = STATE_MQTT_SUB_1;
else
break;
case STATE_MQTT_SUB_1:
ret = RIL_MQTT_QMTSUB(0, 1,topic_update, 1,NULL);
APP_DEBUG("<-- mqtt subscribe, ret=%d -->\r\n",ret);
if(ret ==0)
m_tcp_state = STATE_MQTT_SUB_2;
else
m_tcp_state = STATE_MQTT_CLOSE;
break;
case STATE_MQTT_SUB_2:
ret = RIL_MQTT_QMTSUB(0, 1,"adpp/#", 1,NULL);
if(ret ==0)
m_tcp_state = STATE_MQTT_PUB;
else
break;
case STATE_MQTT_PUB:
u32 length =0;
length = Ql_strlen(test_message);
ret = RIL_MQTT_QMTPUB(0, 1,1,0, topic_update,test_message,length);
APP_DEBUG("<-- mqtt publish, ret=%d -->\r\n", ret);
if(ret ==0)
m_tcp_state = NULL_STATE;
// m_tcp_state = STATE_MQTT_SUB;
//m_tcp_state = STATE_MQTT_CLOSE;
else
break;
case STATE_MQTT_CLOSE:
ret =RIL_MQTT_QMTCLOSE(0);
APP_DEBUG("<--mqtt CLOSE, ret=%d -->\r\n", ret);
if(ret ==0)
break;
case STATE_GPRS_DEACTIVATE:
ret = RIL_NW_ClosePDPContext();
APP_DEBUG("<-- Set GPRS DEACTIVATE, ret=%d -->\r\n", ret);
if(ret ==0)
m_tcp_state = STATE_TOTAL_NUM;
break;
s32 ret = RIL_AT_SUCCESS;
char strAT[200];
Ql_memset(strAT, 0, sizeof(strAT));
Ql_sprintf(strAT, "AT+QMTCFG=\"KEEPALIVE\",%d\n",connectID);
// Ql_sprintf(strAT, "AT+QMTCFG=\"ALIAUTH\",%d,\"%s\",\"%s\",\"%s\"\n",connectID,product_key,device_name,device_secret);
ret = Ql_RIL_SendATCmd(strAT,Ql_strlen(strAT),NULL,NULL,0);
APP_DEBUG("<-- Send AT:%s, ret = %d -->\r\n",strAT, ret);
if (RIL_AT_SUCCESS != ret)
return ret;
return ret;
MQTT_Param *mqtt_param = (MQTT_Param )userdata;
char head = Ql_RIL_FindString(line, len, mqtt_param->prefix); //continue wait
if(head)
char strTmp[10];
char p1 = NULL;
char p2 = NULL;
p1 = Ql_strstr(head, “:”);
if (p1)
QSDK_Get_Str((p1+1),strTmp, mqtt_param->index);
mqtt_param->data= Ql_atoi(strTmp);
return RIL_ATRSP_SUCCESS;
head = Ql_RIL_FindString(line, len, “OK”);
if(head)
return RIL_ATRSP_CONTINUE;
head = Ql_RIL_FindString(line, len, “ERROR”);
if(head)
return RIL_ATRSP_FAILED;
head = Ql_RIL_FindString(line, len, “+CME ERROR:”);//fail
if(head)
head = Ql_RIL_FindString(line, len, “+CMS ERROR:”);//fail
if(head)
return RIL_ATRSP_CONTINUE; //continue wait
u8 *head = NULL;
u8 uCtrlZ = 0x1A;
MQTT_Param *mqtt_param = (MQTT_Param *)userdata;
head = Ql_RIL_FindString(line, len, "\r\n>");
if(head)
Ql_RIL_WriteDataToCore (mqtt_param->prefix,mqtt_param->length);
Ql_RIL_WriteDataToCore(&uCtrlZ,1);
head = Ql_RIL_FindString(line, len, "ERROR");
if(head)
head = Ql_RIL_FindString(line, len, "OK");
if(head)
head = Ql_RIL_FindString(line, len, "+CMS ERROR:");//fail
if(head)
s32 RIL_MQTT_QMTOPEN( u8 connectID,u8* hostName, u32 port)
char strAT[200];
mqtt_param.prefix="+QMTOPEN:";
mqtt_param.index = 1;
mqtt_param.data = 255;
Ql_sprintf(strAT, "AT+QMTOPEN=%d,\"%s\",%d\n", connectID,hostName,port);
ret = Ql_RIL_SendATCmd(strAT,Ql_strlen(strAT),ATResponse_mqtt_handler,(void* )&mqtt_param,0);
if(RIL_AT_SUCCESS != ret)
APP_DEBUG("\r\n<-- send AT command failure -->\r\n");
return ret;
else if(0 != mqtt_param.data)
APP_DEBUG("\r\n<--MQTT OPEN failure, =%d -->\r\n", mqtt_param.data);
return QL_RET_ERR_RIL_MQTT_FAIL;
return ret;
char strAT[200];
mqtt_param.prefix="+QMTCONN:";
if(NULL != username && NULL !=password)
Ql_sprintf(strAT, "AT+QMTCONN=%d,\"%s\",\"%s\",\"%s\"\n", connectID,clientID,username,password);
else
Ql_sprintf(strAT, "AT+QMTCONN=%d,\"%s\"\n", connectID,clientID);
return ret;
APP_DEBUG("\r\n<--MQTT connect failure, =%d -->\r\n", mqtt_param.data);
return ret;
char strAT[200];
mqtt_param.prefix="+QMTSUB:";
mqtt_param.index = 2;
if(NULL == others)
Ql_sprintf(strAT, "AT+QMTSUB=%d,%d,\"%s\",%d\n", connectID,msgId,topic,qos);
else
return ret;
APP_DEBUG("\r\n<--MQTT subscribe failure, =%d -->\r\n", mqtt_param.data);
return ret;
char strAT[200];
mqtt_param.prefix=data;
mqtt_param.length= length;
Ql_sprintf(strAT, "AT+QMTPUB=%d,%d,%d,%d,\"%s\"\n", connectID,msgId,qos,retain,topic);
ret = Ql_RIL_SendATCmd(strAT,Ql_strlen(strAT),ATResponse_mqtt_handler_pub,(void* )&mqtt_param,0);
return ret;
return ret;
char strAT[200];
Ql_sprintf(strAT, "AT+QMTCLOSE=%d\n",connectID);
return ret;
return ret;
char strAT[200];
mqtt_param.prefix="+QMTUNS:";
if(NULL == others)
Ql_sprintf(strAT, "AT+QMTUNS=%d,%d,\"%s\"\n", connectID,msgId,topic);
else
return ret;
return ret;
#endif // EXAMPLE_TCPSSL
regards
kannannatesh
