MQTT not working on BG95-M3
Hello everyone,
I am using BG95-M3 evaluation board and the public MQTT broker - HiveMQ Cloud Cluster.
The connection between the MQTT broker and BG95 is not working.
Using QNavigator to start the module and send commands.
Log:
/* Start AT SYNC: Send AT every 500ms, if receive OK, SYNC success, if no OK return after sending AT 10 times, SYNC fail */
[2023-03-14 16:15:43:829_S:] AT
[2023-03-14 16:15:43:905_R:] AT
[2023-03-14 16:15:43:905_R:] OK
[2023-03-14 16:15:43:920_S:] ATI
[2023-03-14 16:15:43:982_R:] ATI
[2023-03-14 16:15:43:982_R:] Quectel
[2023-03-14 16:15:43:982_R:] BG95-M3
[2023-03-14 16:15:43:982_R:] Revision: BG95M3LAR02A03
[2023-03-14 16:15:43:982_R:] OK
[2023-03-14 16:15:43:996_S:] ATI
[2023-03-14 16:15:44:104_R:] ATI
[2023-03-14 16:15:44:104_R:] Quectel
[2023-03-14 16:15:44:104_R:] BG95-M3
[2023-03-14 16:15:44:104_R:] Revision: BG95M3LAR02A03
[2023-03-14 16:15:44:104_R:] OK
/* Use ATV1 to set the response format */
[2023-03-14 16:15:44:121_S:] ATV1
[2023-03-14 16:15:44:227_R:] ATV1
[2023-03-14 16:15:44:227_R:] OK
/* Use ATE1 to enable echo mode */
[2023-03-14 16:15:44:536_S:] ATE1
[2023-03-14 16:15:44:612_R:] ATE1
[2023-03-14 16:15:44:612_R:] OK
/* Use AT+CMEE=2 to enable result code and use verbose values */
[2023-03-14 16:15:44:758_S:] AT+CMEE=2
[2023-03-14 16:15:44:827_R:] AT+CMEE=2
[2023-03-14 16:15:44:827_R:] OK
/* Get the baudrate, if the value is 0 (auto baudrate), then it will be set to 115200 (fixed baudrate) to assure reliable communication and avoid any problems caused by undetermined baudrate between DCE and DTE, value of IPR should be saved with AT&W */
[2023-03-14 16:15:45:077_S:] AT+IPR?
[2023-03-14 16:15:45:152_R:] AT+IPR?
[2023-03-14 16:15:45:152_R:] +IPR: 115200
[2023-03-14 16:15:45:152_R:] OK
/* Use ATI to get module information of Manufacturer ID, Device module and Firmware version */
[2023-03-14 16:15:45:186_S:] ATI
[2023-03-14 16:15:45:261_R:] ATI
[2023-03-14 16:15:45:261_R:] Quectel
[2023-03-14 16:15:45:261_R:] BG95-M3
[2023-03-14 16:15:45:261_R:] Revision: BG95M3LAR02A03
[2023-03-14 16:15:45:261_R:] OK
/* Use AT+GSN to query the IMEI of module */
[2023-03-14 16:15:45:372_S:] AT+GSN
[2023-03-14 16:15:45:446_R:] AT+GSN
[2023-03-14 16:15:45:446_R:] 864145065372474
[2023-03-14 16:15:45:446_R:] OK
[2023-03-14 16:15:45:447_S:] AT+QURCCFG=“URCPORT”,“uart1”
[2023-03-14 16:15:45:508_R:] AT+QURCCFG=“URCPORT”,“uart1”
[2023-03-14 16:15:45:508_R:] OK
/* Use AT+CPIN? to query the SIM card status : SIM card inserted or not, locked or unlocked */
[2023-03-14 16:15:46:037_S:] AT+CPIN?
[2023-03-14 16:15:46:096_R:] AT+CPIN?
[2023-03-14 16:15:46:096_R:] +CPIN: READY
[2023-03-14 16:15:46:096_R:] OK
/* Use AT+CIMI to query the IMSI of SIM card */
[2023-03-14 16:15:46:225_S:] AT+CIMI
[2023-03-14 16:15:46:300_R:] AT+CIMI
[2023-03-14 16:15:46:300_R:] 404950984534526
[2023-03-14 16:15:46:300_R:] OK
/* Use AT+QCCID to query ICCID number of SIM card */
[2023-03-14 16:15:46:441_S:] AT+QCCID
[2023-03-14 16:15:46:514_R:] AT+QCCID
[2023-03-14 16:15:46:514_R:] +QCCID: 8991000907285370811F
[2023-03-14 16:15:46:514_R:] OK
/* Use AT+CSQ to query current signal quality */
[2023-03-14 16:15:46:546_S:] AT+CSQ
[2023-03-14 16:15:46:607_R:] AT+CSQ
[2023-03-14 16:15:46:607_R:] +CSQ: 27,99
[2023-03-14 16:15:46:607_R:] OK
/* Use AT+CREG? /AT+CGREG? to query the network registration status. */
[2023-03-14 16:15:46:610_S:] AT+CREG?
[2023-03-14 16:15:46:683_R:] AT+CREG?
[2023-03-14 16:15:46:683_R:] +CREG: 0,5
[2023-03-14 16:15:46:683_R:] OK
[2023-03-14 16:15:46:700_S:] AT+CGREG?
[2023-03-14 16:15:46:786_R:] AT+CGREG?
[2023-03-14 16:15:46:786_R:] +CGREG: 0,5
[2023-03-14 16:15:46:786_R:] OK
/* Use AT+COPS? to query current Network Operator */
[2023-03-14 16:15:46:811_S:] AT+COPS?
[2023-03-14 16:15:46:887_R:] AT+COPS?
[2023-03-14 16:15:46:887_R:] +COPS: 0,0,“airtel”,0
[2023-03-14 16:15:46:887_R:] OK
/Use AT+CEREG? to query current EPS Network Registration Status/
[2023-03-14 16:15:46:921_S:] AT+CEREG?
[2023-03-14 16:15:46:997_R:] AT+CEREG?
[2023-03-14 16:15:46:997_R:] +CEREG: 0,4
[2023-03-14 16:15:46:997_R:] OK
[2023-03-14 16:15:47:029_S:] AT+CLVL=?
[2023-03-14 16:15:47:089_R:] AT+CLVL=?
[2023-03-14 16:15:47:089_R:] ERROR
[2023-03-14 16:16:23:645_S:] AT+QMTOPEN=0,“aa992047873c4901b75e1ffa261d82dc.s2.eu.hivemq.cloud”,8883
[2023-03-14 16:16:23:725_R:] AT+QMTOPEN=0,“aa992047873c4901b75e1ffa261d82dc.s2.eu.hivemq.cloud”,8883
[2023-03-14 16:16:23:725_R:] OK
[2023-03-14 16:16:24:935_R:] +QMTOPEN: 0,0
[2023-03-14 16:16:42:253_S:] AT+QMTCONN=0,“bg95”,“ltedev”,“ltedev123”
[2023-03-14 16:16:42:316_R:] AT+QMTCONN=0,“bg95”,“ltedev”,“ltedev123”
[2023-03-14 16:16:42:316_R:] ERROR
[2023-03-14 16:17:26:867_R:] +QMTSTAT: 0,1
How can i connect to a MQTT broker using BG95?
You may not have configured the relevant SSL configuration and the MQTT will not connect.Do you have relevant guidance documents? If not, I will send the relevant guidance documents of MQTT to you.
Please send the guidance documents for MQTT
Quectel_BG95&BG77&BG600L_Series_MQTT_Application_Note_V1.1.pdf
HI,
I followed that MQTT document and trying to use MQTT without SSL.
I have tried again but MQTT is still not working. I am using MQTT without SSL. Trying to connect to HiveMQ MQTT Broker.
Sorry for replying you so late. Could you please check whether the following parameters are correct
< clientI
D> [,<username>[,<password>]]
