MQTT clean session parameters
Hi, I am trying to use the Nimbelink Skywire BG95 modem to do MQTT communication. The problem is that I am setting the clean session parameters to false using the AT+QMTCFG session,0,0 command, but when we look at the session settings in the MQTT broker RabbitMQ, it always shows clean session as true. Is this something that may require a firmware update to work? Or is there something I may be missing that you can guide me towards?
Hi @fluffycat1234
May i to know which FW version are you using now? (AT+QGMR) and does clean session not working or just not re-flashed on MQTT broker?
