I’m using a MH8001-EU module. I accidentally switched it to PCIe mode using AT commands, and now the host system can no longer detect the module.
I tried to connect via the UART interface to change it back to USB mode, but it requires a login username and password.
Could you please provide the ADB or UART login credentials for this module? Also, after login, how can I switch the module back to USB mode?
Here are some details of the system and logs:
- quectel-v: v1.0
- quectel-ID: 26407312
Serial output:
yaml
复制编辑
Password:
Login timed out after 60 seconds.
QTI Linux reference nogplv3 distro targeting performance builds.
LE.UM.5.3.2.x1-06300-SDX65.0 sdxlemur ttyMSM0
sdxlemur login:
Serial log:
csharp
复制编辑
[FAILED] Failed to start pcie Service. See 'systemctl status pcie.service' for details.
Starting usb Service...
Starting IPACM Service...
[FAILED] Failed to start pcie-diag Service. See 'systemctl status pcie-diag.service' for details.
I would really appreciate your support to help me resolve this. Thank you!
