MC60 Sleep Mode does not work due to DTR pin used as External Interrupt pin
With MC60 we are using external interrupt (for accelerometer) on DTR (pin 37). This seems to be only pin on which MC60 supports external interrupts.
We also want to use Sleep Mode (minimum functionality mode CFUN=0 with Ql_SleepEnable). Now the problem is because DTR pin (used as external interrupt source) wakes up the decide due to accelerometer interrupt, and the device is not able to go in Sleep Mode as it’s waking up with external interrupt.
How can I disable wake functionality with DTR pin so that I can use this pin exclusively for the external interrupt?
There are seven pins possesses external interrupts and the external interrupts will wake the model up when in sleep mode.
