Hi
i work with MC60 OpenCpu
SDK_VER: OpenCPU_GS3_SDK_V1.6
CORE_VER: MC60CAR01A13
after set command
ret = RIL_SSL_QSSLOPEN(m_SrvADDR, m_SrvPort_STR, ssid, ctxindex, mode);
Sometimes and not always module reset
What should be done to solve the problem?
thanks alot
Hi
When the module RF is working, a large current will be generated, which will lower the vbat voltage.
Monitor the voltage of the VABT/VDD to see if a voltage drop causes the module to restart.
Also check the code to see if an abnormal parameter was passed that caused module dump to restart
