Thnx mate, Just reflush with firmware and everything back to normal!
Hello @chandan90420,
I also have this error. How to solve ?
/usr/bin/sh: -c: line 0: syntax error near unexpected token (' /usr/bin/sh: -c: line 0:
if not exist build\gcc (md build\gcc)’
make.exe[1]: *** [CreateDir] Error 258
make: *** [all] Error 2
Help me !! Thanks.
Good afternoon,
Had the same problem with Windows 10 x64 bits
Just to add, I followed all the steps, and also delete the CFG file, because it doesn’t overwrite. So it worked correctly.
How to fix “FAIL, Error ROM 4, 0x10000000” error:
- Open uninstall programs section in control panel.
- Check your programs, If you don’t have Microsoft visual C++ 2010 redistributable, download it (if you have a 64 bit system, download both x86 and x64). (I emphasize that even if you have other versions of that, be sure to install the 2010 version as well.)
Install it. - Build your MC60 program again.
Load .cfg file in Qflash - Congratulations, files loaded into Qflash perfectly.
- Program your MC60 and enjoy it.
did you ever solve that problem? i am facing the exact same issue
