I am using RF cable to connect the 5G RM520N-GL with network. But for this I want one antenna that would work for me with better signal signal strength. So which antenna, 0 1 2 3. Kindly direct me on this issue.
Dear @danyal_khattak
As mentioned as below, different antennas has different definition. It is not recommended to use only one.
I can see that RM520N GL doesnot work well with 5GM2EVB board. Do i have to update the firmware? When i use RMU500 EVB it works fine but not on the other.
Kindly send me the latest firmware for RM520N GL.
Please share your current firmware of RM520N.
RM520N can work with M2EVB,I will share user guide to you, please check.
