M95M3 QueckPython and Standard Firmware Issue
I have an M95 module, and I need to load the specific firmware to enable QueckPython functionality. However, I will also need to restore the original firmware to use the module in its normal state. Unfortunately, I can’t find the original firmware. Could you please assist me with this?
If you could share the firmware files with me, I would have the opportunity to test QueckPython and safely restore the module to its original state.
Thank you for your help!
Best regards,
hi,
Could you please provide the specific module model and your email address? I will send the firmware to you by email
berkcekisbas@hotmail.com
BG95-M3 Q1-A8232
BG95M3LA-64-SGNS
BG600L-M3 Q1-A4984
BG600LM3AA-D08-SGNSA
Thank you
I have emailed you the firmware, please try it, thank you
I received your email, thank you very much for your support.
“I successfully installed QuecPython firmware on the module without any issues, but now I want to return to the original AT firmware. However, I’m unable to load this firmware. Can you help me?”
hi,berk
I have sent the firmware to you by email, please try it, thank you
