Buongiorno, io ho un router LTE5398-M904 con versione firmware V1.00(ABVQ.6)C0, mentre il modulo è EG18EAPAR01A12M4G e il mio operatore è Windtre. Per caso ci sarebbero versioni nuove del modulo? Se si potreste mandarmelo. Grazie.
Hi Awake,
Thank you for your patience.
I will check and provide you latest Firmware once available via email.
Thank you and have a nice day!
ciao mi unisco anche io alla richiesta .
sarebbe possibile avere un archivio con tutte le versioni rilasciate ?
in alternativa le ultime 2?
grazie
I attempted to update the module via SSH using QFirehose, but the router’s hardware watchdog triggered a reboot during the process, interrupting the flash.
The process stopped exactly at this point: [011.656]: <erase PAGES_PER_BLOCK="64" ... label="recoveryfs" ... />
As a result, the partition table is erased, and the module is now stuck in Emergency/Recovery mode (no network connectivity).
Could you please send me the DFOTA file (.zip) compatible with the Zyxel Web GUI update?
I cannot use QFirehose anymore due to the aggressive watchdog on this device, so I need the .zip package to flash it via the router’s web interface.
Thank you for your support.
