I want to connect this data to the Quectel module after encoding the image with h264 in an MCU connected to the camera with CSI, I will transfer live images. I want to use LTE module but I don’t know which is the most optimized solution. The image will be 720p 60fps and 1080p 30fps.
Hi @Hamza_Ozdemir
In view of the fact that you need to transmit real-time images in real time, it is recommended that you buy LTE-A or 5G modules to obtain higher transmission rates. The specific model can be selected according to your budget.
Is it possible to connect both lte and lte-a modules of quectel to a stm32 family? Does quectel act as a device or host during this connection? Should I write my own driver to send at commands during this connection?
