LTE Connection Drops Every 3-5 Minutes on Quectel EC200A-EUHA
Here’s your forum post in English:
Title: LTE Connection Drops Every 3-5 Minutes on Quectel EC200A-EUHA
I’m using a modem with the Quectel EC200A-EUHA module, and I’m experiencing frequent disconnections. When connected to LTE, my connection drops approximately every 3 to 5 minutes and reconnects after a few seconds.
Details:
  • I’m using a KLPDA18Dbi directional antenna for LTE. Initially, I suspected a weak signal, but after checking with AT+QENG=servingcell, I found that the signal is in good condition:
    +QENG: "servingcell","NOCONN","LTE","FDD",432,12,A122503,243,6250,20,3,3,791D,-87,-10,-78,14,52
  • My module’s firmware version:
    AT+CGMR
    EC200AEUHAR01A03M16
  • When the connection drops, the modem logs show the following (not sure if this is directly related to the module):
    Mar 14 15:15:18  usb 1-1: USB disconnect, device number 12
Mar 14 15:15:18 cdc_ether 1-1:1.0 usb0: unregister ‘cdc_ether’ usb-rtl819x-ehci-1, CDC Ethernet Device
Mar 14 15:15:18 option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Mar 14 15:15:18 option 1-1:1.2: device disconnected
Mar 14 15:15:18 option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
Mar 14 15:15:18 option 1-1:1.3: device disconnected
Mar 14 15:15:22 -----update_users_traffic, 667, 2, 0, 0, 0
Mar 14 15:15:24 usb 1-1: new high-speed USB device number 13 using rtl819x-ehci
Mar 14 15:15:24 usb 1-1: New USB device found, idVendor=2ecc, idProduct=3001
Mar 14 15:15:24 usb 1-1: New USB device strings: Mfr=3, Product=2, SerialNumber=0
Mar 14 15:15:24 usb 1-1: Product: WUKONG
Mar 14 15:15:24 usb 1-1: Manufacturer: MARVELL
Mar 14 15:15:24 usb 1-1: USB disconnect, device number 13
Mar 14 15:15:32 usb 1-1: new high-speed USB device number 14 using rtl819x-ehci
Mar 14 15:15:32 usb 1-1: New USB device found, idVendor=2c7c, idProduct=6005
Mar 14 15:15:32 usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Mar 14 15:15:32 usb 1-1: Product: Android
Mar 14 15:15:32 usb 1-1: Manufacturer: Android
Mar 14 15:15:32 usb 1-1: SerialNumber: 0000
Mar 14 15:15:32 cdc_ether 1-1:1.0 usb0: register ‘cdc_ether’ at usb-rtl819x-ehci-1, CDC Ethernet Device, 02:0c:29:a3:9b:6d
Mar 14 15:15:32 option 1-1:1.2: GSM modem (1-port) converter detected
Mar 14 15:15:32 usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
Mar 14 15:15:32 option 1-1:1.3: GSM modem (1-port) converter detected
Mar 14 15:15:32 usb 1-1: GSM modem (1-port) converter now attached to ttyUSB1
Mar 14 15:15:46 -----update_users_traffic, 667, 1, 0, 0, 0
Mar 14 15:21:57 usb 1-1: USB disconnect, device number 14
Mar 14 15:21:57 cdc_ether 1-1:1.0 usb0: unregister ‘cdc_ether’ usb-rtl819x-ehci-1, CDC Ethernet Device
Mar 14 15:21:57 option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Mar 14 15:21:57 option 1-1:1.2: device disconnected
Mar 14 15:21:57 option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
Mar 14 15:21:57 option 1-1:1.3: device disconnected
Mar 14 15:22:02 -----update_users_traffic, 667, 2, 0, 0, 0
Mar 14 15:22:03 usb 1-1: new high-speed USB device number 15 using rtl819x-ehci
Mar 14 15:22:03 usb 1-1: New USB device found, idVendor=2ecc, idProduct=3001
Mar 14 15:22:03 usb 1-1: New USB device strings: Mfr=3, Product=2, SerialNumber=0
Mar 14 15:22:03 usb 1-1: Product: WUKONG
Mar 14 15:22:03 usb 1-1: Manufacturer: MARVELL
Mar 14 15:22:03 usb 1-1: USB disconnect, device number 15
Mar 14 15:22:11 usb 1-1: new high-speed USB device number 16 using rtl819x-ehci
Mar 14 15:22:11 usb 1-1: New USB device found, idVendor=2c7c, idProduct=6005
Mar 14 15:22:11 usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Mar 14 15:22:11 usb 1-1: Product: Android
Mar 14 15:22:11 usb 1-1: Manufacturer: Android
Mar 14 15:22:11 usb 1-1: SerialNumber: 0000
Mar 14 15:22:11 cdc_ether 1-1:1.0 usb0: register ‘cdc_ether’ at usb-rtl819x-ehci-1, CDC Ethernet Device, 02:0c:29:a3:9b:6d
Mar 14 15:22:11 option 1-1:1.2: GSM modem (1-port) converter detected
Mar 14 15:22:11 usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
Mar 14 15:22:11 option 1-1:1.3: GSM modem (1-port) converter detected
Mar 14 15:22:11 usb 1-1: GSM modem (1-port) converter now attached to ttyUSB1
Mar 14 15:22:26 -----update_users_traffic, 667, 1, 0, 0, 0
It seems that the USB device is constantly **disconnecting and reconnecting**.
**Questions:**
1. Could this issue be caused by a **firmware bug**?
2. Has anyone faced a similar issue and found a solution?
3. Could adjusting **AT commands** help resolve this problem?
**Thanks in advance for any help!** 🙏
Just from the log, it seems that the EC200A is restarting.
It is better to check the hardware first.
I checked the hardware, it is completely healthy. It’s really strange that such an issue occurs. The network uptime is maximum 5 minutes even though I have very good RSRP and SINR indicators.
The modem is restarting. Please check the RESET and the VBAT.
