Accessing the Linksys velop login page using the default web URL myrouter.local or the IP address 192.168.1.1 can help you get to the main Linksys Velop setup wizard. However, you’ll need to first connect your device to the Velop’s router network. Once connected, you can proceed with the login process and head to the main setup wizard. Once you have access to the setup wizard, you can navigate through the setup instructions to complete the network and device setup.
