LG290P only 10Hz?
I appeared to successfully change the update rate to 50ms:
$PQTMCFGFIXRATE,W,50*5D
But I’m only getting fixes every 100ms? Is there something else to change, or does the 290 not run at 20Hz? I tried a few timings and it definitely has preferred intervals, eg 110ms failed. I haven’t tried RTK, yet. I have the same aliexpress module as a lot of others here.
I’ll actually use the LG290 as a base station, but if it can run at 20Hz+, I’ll get an LG580 for the ‘rover’.
…probably depends on the firmware version.
I can’t verify because I left the board
see the different notes: 2.3.15. PQTMCFGMSGRATE
but
It worked after a power cycle. It now gives a fix every 50ms. I had got used to things happening after a $PQTMSRR…
Bom dia! Quanto ficaria o CEP do LG290P sem nenhum tipo de correção? Somente com sinal das constelações! Eu não encontrei essa informação.
Eu tenho um LC 29HEA e está complicado pra fazer as correções, e se tivesse uma decisão entre 20 a 30 centímetros já seria satisfatório, mas não é o caso do LC29H EA .
Hi @Vegeta10
The CEP 50 for LG290P without RTK services is 70 centimeter
Are you facing issue in RTK setup with LC29HEA?
