LG290P firmware update error
Hi, I tried to update the LG290P firmware but at the end of the procedure I got an error (attached).
I also tried with qgnss2 but I got error 0x400.
How do I solve it?
Thanks for your interest
AF
How do I solve it?
thanks for your interest
AF
did you reset the module after you pressed the go button? the procedure is documented in the upgrade manual.
Thank you very much Lawnsweeper! How do I manually reset the module within 90? Do I have to unplug it and reattach it? Is this what I don’t understand? I thought the procedure did everything automatically!?
If you can give me further information, I’d appreciate it!
AF
if you have the lg290p board from aliexpress/etc., there is a reset button on it. just push it after you press go.
otherwise you’ll have to momentarily ground the reset pin. if you are not using usb to communicate with it, you could unplug and replug it. this probably won’t work with usb since the serial port will disappear.
Great Lawnsweeper, I solved it thanks to your information! I finally updated the LG290P firmware successfully.
My LG290P (mozihao) bought on aliexpress luckily has the reset button!
Thanks again for your assistance.
Greetings and have a good day!
AF
glad you got it figured out!
