LCH29HBS No reply from survey-in status command
I’m sure this is just a simple noob issue, but I cannot get a reply to the survey-in status, $PQTMSVINSTATUS. All other commands return the expected result.
I have tried sending $PQTMSVINSTATUS*0E, and $PQTMSVINSTATUS with no checksum, neither work.
What am I doing wrong?
Firmware version: $PQTMVERNO,LC29HBSNR11A01S,2023/02/13,10:14:06*27
Enable the Survey-In observation results
$PQTMCFGMSGRATE,W,PQTMSVINSTATUS,1,1*58
Disable the Survey-In observation results
$PQTMCFGMSGRATE,W,PQTMSVINSTATUS,0,1*59
$PQTMCFGSVIN,W,2,0,0,x,y,z*<Checksum> #Set the base in ecef
$PQTMCFGSVIN,R*26 check if ecef base is correct
Thank you. I see how that works now, and can see the data.
