LC29HDA Stuck in boot
Hi my LC29HDA module stucks in this loop writing this over and over again.
What can i do?
Thanks in advance.
F1: 0000 0000
V0: 0000 0000 [0001]
00: 0000 0000
U0: 0000 0001 [0000]
T0: 0000 00B2
Leaving the BROM
bootloader start!
bl_uart_init
hal_clock_set_pll_dcm_init
hal_emi_configure
rising freq to 384m level pass!
hal_flash_init
hf_fsys_ck freq=384079
hf_fsfc_ck freq=96019
bl_fota_process
info_type:0x1, record_data:0x400ffe0, record_len:2
info_type:0x1, info->is_init:0
Found, partition_type:10
fota_multi_info_start_addr_get() info_type:1 addr:0x26f000 storage_type:0
fota_multi_info_start_addr_get() info_type:2 addr:0x26f100 storage_type:0
info_type:0x1 start_addr:0x26f000 last_record_addr:0x26f000 data_num:0 history_record_count:0
ret:0, record_data:0xff 0xff
FOTA state: 0x1
info_type:0x2, record_data:0x400ffb4, record_len:2
info_type:0x2, info->is_init:0
fota_multi_info_start_addr_get() info_type:4 addr:0x26f180 storage_type:0
info_type:0x2 start_addr:0x26f100 last_record_addr:0x26f100 data_num:0 history_record_count:0
upgrade_flag :0
Partition(0) 0x8013000
Jump to addr 0x8013000
LC29HDANR11A03S_RSA
$1,20381121,3072,1,7,126
$PAIR011,001
27
@June_Zhu I bought a mikroe kit and got the same issue, can I have the latest FW for LC29HDA and LC29HAA?
Thanks, much appreciated.
Hi MaGhost75,
I will send you the latest LC29HDA firmware through email. Please try to flash the firmware to the module, and see if this issue resolve.
Best regards.
Hi Carlitos,
I will send you the latest LC29HDA and LC29HAA firmware through email.
Best regards.
Get stuck with error while trying to Flash.
Think it is burned.
But then it should not send any reply at all I think.
