LC29H DA stopped working in RTK
Hi all,
I have an LC29HDA which was working fine both in the Quectel QGNSS software and with an Android RTK mapping program. It would obtain an RTK fix with good performance from a nearby caster via RTK2GO.
I experimented in putting it into base mode for use with a Pi RTK casting software and even after restoring it to rover mode using the commands in the documentation, and reconfiguring NMEA it now no longer achieves a fix or float. The best positioning it achieves is DGPS.
Have I missed a command somewhere, such as enabling RTCM input?? I have searched but can’t find a reference to one. Could someone give me a complete list of the $PQTM / PAIR messages needed to enable rover mode with RTCM input and the order in which they should be input. I am hoping it’s something simple in the config messages, or have I somehow bricked the unit and rendered it useless??? If so, this isn’t really something that should happen and there should be a way to restore it. I don’t have firmware, I can flash to see if this resets it to out of box status as you can’t download any.
My current firmware is My current version is $PQTMVERNO,LC29HDANR11A03S_RSA,2024/03/19,13:55:31*20
Hi @Bob_Mcnair
I have sent the latest firmware and technology document of LC29HDA to you through email, please check it.
And also you could send the the module’s log of the question you encounter to me, then i will help you fix this question.
Best regards
