Hello, I have this firmware:
at+qgmr
RG255CGLABR01A04M4G_A0.300.A0.300
I am running linux kernel:
uname -a
Linux exeltel 6.16.7+deb14-rt-amd64 #1 SMP PREEMPT_RT Debian 6.16.7-1 (2025-09-11) x86_64 GNU/Linux
I can’t use minicom + quectel-CM to control the rg255. minicom works with the “option” kernel module, so I can have AT commands, but then there is no network interface created. If I remove “option” and use only “qmi_wwan” then quectel-CM fails with those repeated logs:
[01-20_12:33:03:795] QmiWwanThread poll err/hup/inval
[01-20_12:33:03:795] poll fd = 7, events = 0x0008
I would like to have a more recent firmware, if any.
Also, a version of qmi_wwan_q than can compile for my kernel version (I have 1.2.7, which fails to compile).
And finally, a version of QConnectManager that would work for my setup. I have 1.6.7.
If anything else is needed for a proper usage of the rg255 on my setup, please provide it as well, thank you.
Thank you by advance, and I can provide more information if needed.
