Hi,@maridc
I have sent to you via private message,pls check.
Can I have the latest firmware for EG21-G? My existing module have this version: EG21GGBR07A11M1G_30.202.30.202, and seems like the CMUX communication basically just dead after I set AT+CMUX=0,0,5,127,10,3,30,10,2
Hi,@krisna
I have sent to you via email,pls check.
Please sumit Firmware and Flashing Toll Instaction for: EG25GGCR07A02M1G
I found Device in Ubuntu but it seems some more driver is needed. no Signal from a wokring SIm Card.
Thank you very much.
I have sent it to you,pls check,and I hope you can click the
for me,thx
Can I get the latest firmware EG21GLGAR07A03M1G_01.201.01.201
WITH TOOL THANKS
Could you share your current firmware version? Much appreciation
for me,thx
Hello ā thanks, I received it. Could I also get the flashing tool and the documentation for how to flash the EG21? Thanks.
Hello, Quectel Team!
Iād lilke to have the most recent version of firmware for EG21GGB-128-SGNS modem, the flashing tool and a quick guide of how to do it.
Thank you!
I have purchased a Quectel EG25-G LTE module, and I would like to use it connected to the mini PCIe interface available on my NXP GoldBox-3 board (s32g399ardb3).
Once physically attached to the interface, I can confirm that the module is properly powered, but Iām not able to detect it as a WAN interface on the board.
Iād like to have the most recent version of firmware for EG25-G modem, the flashing tool and a quick guide of how to do it. Could you specify also if there are any mandatory Linux Kernel modules to check if they are enabled in my Yocto build?
Thank you!
I have sent them to you,pls check
Got them, thanks a lot!
Hello, could I have a reply too asap? Thanks in advance ![]()
The exact model, if needed, is the following: EG25GGB-256-SGNS
Hello again, Quectel team!
Iād be very appreciated if you will send me an old firmware as well, exactly this one EG21GGBR07A11M1G_30.002.30.002 Dec 2 2021 10:52:06.
Thank you!
I am using EG21-GL and EG21-G modems with the following versions.
- EG21GLGDR07A03M1G
- EG21GGBR07A11M1G
Could I please have the latest firmware for these, so I can update/restore as required.
Thanks,
Brendan Simon
