What information do you need to check? Can I help you?
we need to check the SIB2-NB and SIB3-NB content.
Are you able to display it on ASN1 pane ?
00004B257BEFA078FCD10A02681225269292B26A31ECB04828021D03802C66625B018BDAF107000000
BCCH-DL-SCH-Message-NB
message: c1 (0)
c1: systemInformation-r13 (0)
criticalExtensions: systemInformation-r13 (0)
sib-TypeAndInfo-r13: 1 item
Item 0
sib-TypeAndInfo-r13 item: sib2-r13 (0)
sib2-r13
radioResourceConfigCommon-r13
rach-ConfigCommon-r13
preambleTransMax-CE-r13: n10 (6)
powerRampingParameters-r13
powerRampingStep: dB2 (1)
preambleInitialReceivedTargetPower: dBm-116 (2)
rach-InfoList-r13: 3 items
Item 0
RACH-Info-NB-r13
ra-ResponseWindowSize-r13: pp10 (7)
mac-ContentionResolutionTimer-r13: pp16 (5)
Item 1
RACH-Info-NB-r13
Item 2
RACH-Info-NB-r13
connEstFailOffset-r13: 0 dB
bcch-Config-r13
modificationPeriodCoeff-r13: n16 (0)
pcch-Config-r13
defaultPagingCycle-r13: rf1024 (3)
nB-r13: one1024thT (12)
npdcch-NumRepetitionPaging-r13: r128 (7)
nprach-Config-r13
nprach-CP-Length-r13: us266dot7 (1)
rsrp-ThresholdsPrachInfoList-r13: 2 items
Item 0
RSRP-Range: -115dBm <= RSRP < -114dBm (26)
Item 1
RSRP-Range: -125dBm <= RSRP < -124dBm (16)
nprach-ParametersList-r13: 3 items
Item 0
NPRACH-Parameters-NB-r13
nprach-Periodicity-r13: ms320 (4)
nprach-StartTime-r13: ms8 (0)
nprach-SubcarrierOffset-r13: n12 (1)
nprach-NumSubcarriers-r13: n12 (0)
nprach-SubcarrierMSG3-RangeStart-r13: one (3)
maxNumPreambleAttemptCE-r13: n5 (2)
numRepetitionsPerPreambleAttempt-r13: n1 (0)
npdcch-NumRepetitions-RA-r13: r4 (2)
npdcch-StartSF-CSS-RA-r13: v4 (2)
npdcch-Offset-RA-r13: zero (0)
Item 1
nprach-StartTime-r13: ms256 (5)
numRepetitionsPerPreambleAttempt-r13: n4 (2)
npdcch-NumRepetitions-RA-r13: r32 (5)
npdcch-StartSF-CSS-RA-r13: v2 (1)
Item 2
nprach-Periodicity-r13: ms640 (5)
nprach-StartTime-r13: ms64 (3)
numRepetitionsPerPreambleAttempt-r13: n16 (4)
npdcch-NumRepetitions-RA-r13: r64 (6)
npdcch-Offset-RA-r13: threeEighth (3)
npdsch-ConfigCommon-r13
nrs-Power-r13: 29 dBm
npusch-ConfigCommon-r13
ack-NACK-NumRepetitions-Msg4-r13: 3 items
Item 0
ACK-NACK-NumRepetitions-NB-r13: r1 (0)
Item 1
ACK-NACK-NumRepetitions-NB-r13: r4 (2)
Item 2
dmrs-Config-r13
threeTone-CyclicShift-r13: 1
sixTone-CyclicShift-r13: 1
ul-ReferenceSignalsNPUSCH-r13
… .0.. groupHoppingEnabled-r13: False
groupAssignmentNPUSCH-r13: 0
uplinkPowerControlCommon-r13
p0-NominalNPUSCH-r13: -110 dBm
alpha-r13: al1 (7)
deltaPreambleMsg3-r13: 2dB (1)
nprach-Config-v1330
nprach-ParametersList-v1330: 3 items
Item 0
NPRACH-Parameters-NB-v1330
nprach-NumCBRA-StartSubcarriers-r13: n12 (3)
Item 1
Item 2
ue-TimersAndConstants-r13
t300-r13: ms6000 (2)
t301-r13: ms6000 (2)
t310-r13: ms8000 (6)
n310-r13: n10 (6)
t311-r13: ms1000 (0)
n311-r13: n1 (0)
freqInfo-r13
ul-CarrierFreq-r13
carrierFreq-r13: 24279
carrierFreqOffset-r13: v6 (17)
additionalSpectrumEmission-r13: 1
timeAlignmentTimerCommon-r13: infinity (7)
SIB.txt (9.7 KB)
Hi @herbert.pan-Q , a happy new year!
Could you send me EPAT and DB for BC660KGLAAR01A05 as well? THanks.
WIll
afterwards ![]()
I have sent the latest firmware version to you, the DB file is included in the firmware package, if you are not the latest version, I suggest you upgrade to the latest version first
Hi @herbert.pan-Q Could you send the EPAT tool?
Thank you
I have sent it to you,pls check,I hope you can click the
for me, thanks
Hi @herbert.pan-Q sorry to contact you again, can you send me the DB file for the firmware VERSION: BC660KGLAAR01A05?
Thank you
Please provide more detailed firmware version
AT+QGMR
Here is the requested output:
Revision: BC660KGLAAR01A05_01.200.01.200
I have sent it include firmware to you,pls check,I hope you can click the
for me, thanks
Hello @herbert.pan-Q could you please send me EPAT tool and db for BC660KGLAAR01A05_01.203.01.203? Thank you from advance!
My mail is info@petermarkl.com
I have sent it include firmware and EPAT to you,pls check,I hope you can click the
for me, thanks
Hi @herbert.pan-Q, can you please send me the DB file for the firmware VERSION: BC660KGLAAR01A05_01.002.01.002?
comdb.txt (1.5 MB)
i AM USING BC660KGLAAR01A05_01.205.01.205 VERSION.
I need latest DB file and latest EPAT TOOL for logging the logs.
Email : mahek.yadav@smartmeters.co.in
comdb.txt (1.4 MB)
for me, thanks
I AM USING BC660KGLAAR01A12_BGJ VERSION.
Email : tahaxaboud@gmail.com
It is a customized version. I couldn’t find the corresponding DB file. I have sent you EPAT. I suggest you capture the Log and send it to Quectel for analysis.
