I’m currently working on a solution involving an MCU and an EG915U modem. However, I’m facing an issue with managing the UART communication between the modem and the MCU. Let me explain the problem in detail:
Hardware Configuration
- The MCU utilizes two UART interfaces:
- SERCOM5: Used to send data externally (currently to a PC via PuTTY).
- SERCOM0: Used to send AT commands to the EG915U modem (via MAIN_TXD/RXD).
- Note: Both UARTs have been tested using an oscilloscope. SERCOM0 was also verified by communicating with a PC via PuTTY. Voltage levels are correct: 1.8V on the EG915U side and 3.3V on the MCU side.
- Pin configuration:
- SERCOM5:
- RX5 → PIN 62 → PB01 → SERCOM5/PAD[3]
- TX5 → PIN 63 → PB02 → SERCOM5/PAD[0]
- SERCOM0:
- RX0 → PIN 14 → PA05 → SERCOM0/PAD[1]
- TX0 → PIN 13 → PA04 → SERCOM0/PAD[0]
- SERCOM5:
Software Logic
The main logic is as follows:
int main() {
/* Initialize all modules */
SYS_Initialize(NULL);
SYSTICK_TimerStart();
// Enable UART transmitter and receiver
SERCOM0_USART_TransmitterEnable();
SERCOM0_USART_ReceiverEnable();
SERCOM5_USART_TransmitterEnable();
SERCOM5_USART_ReceiverEnable();
powerOnModuleQuectel(); // Executed once
send_at_command("ATI\r\n");
SYSTICK_DelayMs(1000); // Allow modem time to respond
receive_response();
// Function to send AT commands
static void send_at_command(const char *command) {
bool result = false;
// Send the AT command
result = SERCOM0_USART_Write((uint8_t *)command, strlen(command));
if (result) {
SERCOM5_USART_Write(&okMessageSERCOM0[0], sizeof(okMessageSERCOM0));
SERCOM5_USART_Write((uint8_t *)command, strlen(command));
} else {
SERCOM5_USART_Write(&errorMessageSERCOM0[0], sizeof(errorMessageSERCOM0));
// Function to receive response
static void receive_response(void) {
char data = 0;
char receiveBuffer[RX_BUFFERS_SIZE] = {};
uint16_t rxCounter = 0;
// Poll for data
SERCOM5_USART_Write(&enter_Poll_for_Data[0], sizeof(enter_Poll_for_Data));
while (SERCOM0_USART_ReceiverIsReady()) {
SERCOM5_USART_Write(&enterWhile[0], sizeof(enterWhile));
SERCOM0_USART_Read(&data, 1); // <--- GETS STUCK HERE
SERCOM5_USART_WriteByte((int)data);
if ((data == '\n') || (data == '\r')) {
SERCOM5_USART_Write(&newLine[0], sizeof(newLine));
SERCOM5_USART_Write(&receiveBuffer[0], rxCounter);
SERCOM5_USART_Write(&exitSERCOM5Write[0], sizeof(exitSERCOM5Write));
break;
} else {
receiveBuffer[rxCounter++] = data;
} // End of while
SERCOM5_USART_Write(&exit_Poll_for_Data[0], sizeof(exit_Poll_for_Data));
Issue Details
The program gets stuck at the following point:
while ((SERCOM0_REGS->USART_INT.SERCOM_INTFLAG & SERCOM_USART_INT_INTFLAG_RXC_Msk) == 0U) {
/* Do nothing */
I’m unsure whether the issue lies in the hardware connections (I’m using a custom board) or in the code itself. Additionally, I’m not certain if hardware flow control (RTS/CTS) is necessary for this setup, though I suspect it may not be required.
Additional Information
Attached are images of the SERCOM0/5 configurations using MPLAB Harmony Version 3.
Any insights or suggestions to resolve this issue would be greatly appreciated.
Thank you in advance for your help!
Best regards,
Fer Mercado.
