Issue with sending URL on AT+QHTTPURL
I’m working with a Quectel EC200U-CN module (firmware version EC200UCNAAR03A03M08) and facing an issue while sending data to the AT+QHTTPURL command.
The module connects to the network and activates PDP context successfully, but when I send the URL after the CONNECT prompt, the module either times out or throws +CME ERROR: 726. It seems that the module is not accepting the input text or file contents after showing CONNECT.
I have tested this behaviour with both QCOM utility and Tera Term, and in both cases, the issue persists — neither manual typing nor sending a .txt file works after the CONNECT prompt.
[2025-10-30_12:45:25:719] AT+QHTTPURL=19,30
[2025-10-30_12:45:25:719] CONNECT
[2025-10-30_12:45:28:373] // where i pasted http://neverssl.com
[2025-10-30_12:45:28:373] OK
[2025-10-30_12:49:22:344] AT+QHTTPURL=19,30
[2025-10-30_12:49:22:344] CONNECT
[2025-10-30_12:49:52:344] +CME ERROR: 726
where this is command sequence i used
AT
AT+CPIN?
AT+CFUN=1
AT+CSQ
AT+CREG=1
AT+CGATT=1
AT+CGDCONT=1,“IP”,“a******.com”
AT+QICSGP=1,1,“a*****.com”,“”,“”,1
AT+QIACT=1
AT+QIDNSCFG=1,“8.8.8.8”,“8.8.4.4”
AT+QHTTPCFG=“contextid”,1
AT+QHTTPCFG=“requestheader”,1
AT+QHTTPCFG=“responseheader”,1
AT+QHTTPCFG=“contenttype”,1
AT+QHTTPURL=19,30 → (CONNECT appears, but input not taken)
pls help me on this
Hi Aravind,
Thank you for contacting us.
If possible, can you share your URL address so that I can test it?
Regards,
Fazrul
