Issue with AT+QGPS=1 on EG800K / GPS support and Firmware update
Hello Quectel Support Team,
We are currently working with the EG800K module and our current firmware version is EG800KEUCCR07A09M02_01.001.01.001.
When we try to turn on the GNSS by sending the AT+QGPS=1 command, we consistently get an ERROR response.
Could you please clarify the following points regarding this module?
**GPS/GNSS Support:**Does this specific module hardware natively support GNSS/GPS functionality?
**Ephemeris via LTE:**If GPS is supported, does it have the capability to download ephemeris data via the LTE network (A-GPS / XTRA) to achieve a faster Time To First Fix (TTFF)?
**Firmware Update:**Is a firmware update required to enable these GNSS features?
**Firmware Request:**If an update is necessary, could you please provide the latest firmware version along with the flashing tool?
Best regards
You are using EU version, just the CN version has GNSS available.
Yes I know but having to use the quectel module in the EU area I was hoping there was also an EU version with GNSS.
