Is there something wrong with the L96-m33 hardware design?
I built a simple board to test the L96-m33. I’m trying to test it in two modes: left and right.
However, I can’t receive GPS data in either mode.
Is there a problem with the hardware design?
Hi @hu_s
Please tell me which antenna is be used. When the built-in patch antenna is used, R1(0) should be mounted. If an external antenna is used, R1(0) should not be mounted.
Your ANTON pin is unused, is your antenna is passive?
Moreover, i have sent technology reference document to you through email. Please check it.
Best regards.
