In which cases will module respond CLOSED?
Module will respond CLOSED in the following three conditions:
  1. TCP connection is closed by the server.
  2. If module still cannot receive ACK from server after re-trying to transmit data to the server for 12 times, it will automatically close TCP connection and respond CLOSED.
  3. TCP connection might be interrupted and module will respond CLOSED due to the abnormality of network.
