IMEISV read/set on EG25-G
is there a way to get/set IMEISV of an EG25-G module ?
I know how to do it for IMEI, but what about IMEISV in case it is requested by a mobile network ?
pls run
AT+CGSN=2
Thx Herbert for this quick answer.
Running fw EG25GGBR07A08M2G, at+cgsn=2 is not supported:
at+cgsn=?
+CGSN:“sn,imei”(0,1)
While waiting for an answer I tested
at+egmr=?
+EGMR: (0,1),(5,7,8,9,10)
Could you confirm that at+egmr=0,9 (or 1,9,”sv”) work ?
AT+EGMR=0,9
Ok.
So as suspected I can use egmr=1,7 and egmr=1,9 ?
Do I have to reboot the modem after that or cfun=0 then cfun=1 is enough ?
Thank you again Herbert
Is there a way to change the SVN so that it stays modified after off/on or even at+cfun=1,1 ?
The tampering of the IMEI is not permitted. If this is a necessary requirement for you, please contact the sales department of Quectel for further communication.
