I am using the Quectel eg25-g. I am trying to move a file from SD card storage to UFS medium. I am able to access the SD card, see the files.
When I try to use the AT+QFMOV command to move the file from SD card to UFS, i get “ERROR”.
Now, to check if the command normally works, i tried:
AT+QFMOV=?
I get an error. this command was mentioned in the official documentation of the module too. I dont know why it does not support it on mine.
Dear Customer,
Could you tell me the firmware version you tried?
