How to use gsm EG91 modem analog output for mic and speaker without external codec
Hi
I am trying to use analog output for mic and speaker for EG91 modem.
I execute below command for analog output:
AT+QDAI=1
AT+QSIDET=5
AT+QAUDLOOP=1 (got error)
But still not able to hear anything. By using external coded everything is working fine.
Hope you can help on this.
Regards,
Rahul
But I don’t see that EG91 supports analog audio output…
I am using the module EG915NEUAGR03A09M16. Upon reviewing the audio AT command manual, I noticed that it mentions the use of a built-in codec.
Could you please clarify what is meant by this?
doc ref: Quectel_EC200x&EG912Y&EG915N_Series_Audio_Application_Note_V1.1.pdf
EG91 is not the same with EG915N.
Please check
AT+QAUDSW?
i am not sure whether it support internal CodeC?
Have you swith it to internel codec?
And the hardware disign for internel CodeC and external CodeC is not the same.
Yes, it has, and I already set to 1
AT+QAUDSW=1 for in built codec
