I am working with two RG530 modules connected to the same Ubuntu 22.04 computer.
- The first RG530 is running on a commercial 5G network and appears as
/dev/ttyUSB0,1,2,3. - The second RG530 is running on an srsRAN network and appears as
/dev/ttyUSB4,5,6,7.
I need to use ./quectel-CM in my python script, but I would like to specify which ttyUSB device it should use.
Is there an option (for example, via ./quectel-CM -?) that allows me to explicitly select the desired ttyUSB number?
Thank you for your help!
