How to set the caller ID and the Connected Line Identification Presentation (CLIP)?
  1. You can use AT+CLIP=1 to present the calling line. And you can set AT+QCLIP=1 to present the string type corresponding to the entry saved in the phone book.
  2. You can use AT+COLP=1 to present the connected line. And you can set AT+QCOLP=1 to present the string type corresponding to the entry saved in the phone book.
Example:
AT+CPBW=1,“02151082965”,129,“QUECTEL” //write phonebook entry
AT+QCLIP=1 // present the string type corresponding to the entry saved in the phonebook
AT+CLIP=1 //calling line identification enabled
RING
+CLIP: “02151082965”,129,"",“QUECTEL”,0 // “QUECTEL” will be presented
AT+QCOLP=1 // present the string type corresponding to the entry saved in the phonebook
AT+COLP=1 //connected line identification enabled
ATD02151082965;
+COLP: “02151082965”,129,"",0,“QUECTEL” // “QUECTEL” will be presented
