in Quecopen C SDK, im able to enable the C++98 compiler option in toolchain, But when i enable the option for C++ 11 or greater than that. Getting compiler error in library files. I have checked compiler is supported till C++20. How to enable the latest version.
Hi @Vasu_P ,
Depending on which SDK you have, C++ support can vary. But mostly it will not be supported, even if compilation passes.
