I am using EC25J now and I need to send HTTP GET request to our server, but HTTP header “Authorization: xxxxxxxxxx” is required, I try to set the AT+QHTTPCFG=“requestheader”,1 and package the HTTP req by myself, but it response CME: 701, please check the HTTP data as below:
‘GET /v1/device_modes/1234 HTTP/1.1\r\nHost: device-server.n-sportstracking-lab.com:30003\r\nAuthorization: NeRQrYM9dfenADGT26sSSADFCQJJEXVQK\r\n\r\n’
Dear Jackie,
About your issue, please double check whether your server can support customize HTTP(S) Request Header, if not support, please change the setting; if it can support, please confirm whether the header is the same as the server required. Thanks!
The following document is HTTPS applictaion note, please double check it. Thanks!
Quectel_LTE_Standard_HTTP(S)_Application_Note_V1.1.pdf (394.7 KB)
