[Help] BG95M3LA-64-SGNS stuck in QDLoader 9008 mode – need firmware and recovery procedure
Hello everyone,
I have a Quectel BG95M3LA-64-SGNS module mounted on a Raspberry Pi Zero-compatible board. After an improper manipulation, the module appears to be bricked: it now shows up in QDLoader 9008 mode in the Windows Device Manager, and the usual USB port for programming is no longer available.
Unfortunately, I do not have any firmware files to attempt a recovery, and I haven’t found a clear procedure to unbrick the module from this state.
I would really appreciate your help with the following:
  1. What is the recommended procedure to recover a BG95-M3 module stuck in QDLoader 9008 mode?
  2. Where can I download the official firmware or recovery image compatible with the BG95M3LA-64-SGNS variant?
  3. Can the QFlash tool be used in this situation, and if so, what file types and steps are required?
Please note that the module was purchased on AliExpress, so I do not have access to support via an official distributor.
Thank you very much for your assistance,
Best regards,
Steef
Hi
Could u tell me what operation u did to make it be bricked?
I was in QPYcom v3.7.0 and I messed around with Download FW in the Download tab.
