Gps modul LP76GAB firmware\android drivers\ The module is not in service area.*31
Hi! I started to add lp76gab into car radiohead and have “The module is not in service area.*31” this error.
  1. Is there any sanctions for Russia region ?
  2. New firmware ?
  3. Drivers for android ?
    Thanks a lot.
The module is not in service area.*31 was in QGNSS 2.0
Hi Sir,
Could you please help double-check the part number of the module? I cannot find the OC LP76GAB.
BR,
June
Hi MONKEYTUN,
Were you referring to LC76AB? You can use the command PQTMCFGGEOFENCE to check if the geofence feature has been enabled.
