FTP Server Error
Dear All, I have a problem with some FTP Server… I got this error -1
AT+QFTPOPEN=“wmsdev.alientech.cloud”,22
AT+QFTPPUT=“text.txt”,15,20
+QFTPPUT:-1
Can I have an help?
Michele
Hi Michele,
Which module did you use? Before you send +QFTPPUT command, you need to wait response of +QFTPOPEN command first, like +QFTPOPEN:0,0
I’m using M66… this the trace… if you can try for me… thanks a lot
Michele
at+csq
+CSQ: 20,0
AT+QIFGCNT=0
AT+QICSGP=1,“mobile.vodafone.it”
AT+QFTPUSER=“nextftp”
AT+QFTPPASS=“NextFtp2020”
AT+QFTPOPEN=“wmsdev.alientech.cloud”,22 ( or 21 )
AT+QFTPPUT=“test.txt”,15,20
+QFTPPUT:-1
Hi Michele,
Please try port 21. And don’t send AT+QFTPPUT before you get response from server for AT+QFTPOPEN command.
Hi Willie… now I got -553 error and this the trace
Thanks in advance
+QFTPCLOSE:0
AT+QIFGCNT=0
AT+QFTPOPEN=“wmsdev.alientech.cloud”,21
+QFTPOPEN:0
+QFTPPUT:-553
FTP conenction is ok. You would need to to set path first. You could refer to example in FTP application note.
Best Regards,
