FOTA IN MC60 OpenCpu
hello
I have a question about FOTA in mc60 opencpu
According to the open cpu user guid documents
I saved the Ql_FOTA_WriteData function to write the frimware data with 512 bytes order, and then without any error, I called the Ql_FOTA_Finish() function, and the answer was QL_RET_OK, and then I called the Ql_FOTA_Update() function, and the module rebooted as expected. The new program is about to be activated, but unfortunately the current program is activated.
Please advise what to do
thank you
Hi
FOTA upgrade is a direct upgrade to the new firmware. You should be using the wrong upgrade package, please check whether your upgrade package is the latest firmware upgrade package.
