I have a Quectel RM520N-GL installed in a GL.iNet GL-X3000 (Spitz AX) router.
My current firmware is:
RM520NGLAAR03A04M4G_01.204.01.204
The modem is connected via PCIe/MHI and is using the mhi-pci-generic driver under Custom OpenWrt.
ModemManager reports:
Model: RM520N-GL
Firmware:
RM520NGLAAR03A04M4G -
PCI ID:
17CB:0308 -
Driver:
mhi-pci-generic -
ModemManager plugin:
quectel
I understand that R03A04 is the PC1.5 firmware branch and I would like to remain on the R03A04/PC1.5 branch.
Could you please provide the latest firmware compatible with my exact RM520N-GL hardware, preferably the latest R03A04 release, together with the corresponding release notes/changelog?
In particular, could you confirm:
The latest recommended firmware version for my current
R03A04modem. -
Whether there is an upgrade newer than
01.204.01.204within the R03A04 / PC1.5 branch. -
Whether the firmware you provide is safe to flash using QFirehose 1.4.17 over PCIe/MHI on the GL-X3000.
Whether there are any specific upgrade restrictions or prerequisites when upgrading from
R03A04M4G_01.204.01.204. -
Whether upgrading to a newer R03A04 release affects or preserves PC1.5 operation.
I have seen newer R03A03 firmware such as RM520NGLAAR03A03M4G_A0.304.A0.304, but I do not want to change branches unless Quectel confirms that it is officially compatible and recommended for my hardware.
Please provide the appropriate firmware package and release notes for my modem.
Thank you.
