Firmware Request for EG915U-EU
see my message herbert need help.
Hello
I’m currently using the EG915U-EU module with firmware version EG915UEUABR03A01M08.
Could you please provide the latest available firmware for this model?
Thank you in advance for your support!
Thank you very much,
I would like to ask for some more help.
The firmware update of the EG915U-EU should be implemented via the MAIN UART, but there is no flow control option. Only TX and RX pins are available. Do you have any solution for this? I am thinking of something like QFlash was in the case of the M95 module. It is not a problem if the process is slow. If there is any description or software for this, please send it to me.
Thank you in advance for your answer
I am currently using the EG915U-EU module with firmware version EG915UEUABR03A01M08_01.004.01.001.
Could you please provide the latest FOTA FIRMWARE available for this model?
Thanks in advance for your support!
Thank you,
What you sent is the Standard update package that can be uploaded to the modem via USB.
I would like to request a FOTA package.
I have sent the delta update package,pls check
Thank you very much.
Hi Quectel team,
I need the latest standard (non-QuecPython/OCPU) AT firmware for EG915U-EUAB to revert from QuecPython.
Current firmware on my module: EG915UEUABR03A06M08_OCPU_QPY_01.300.01.300
Please send the .pac file + QFlash tool + release notes to my email: ilyusel98@gmail.com
Thank you!
I have sent the latest one to your email,pls check
I need the standard non-QuecPython AT firmware for EG915U-EUAB to revert after QuecPython testing.
Current firmware: EG915UEUABR03A01M08_01.300.01.300
QuecPython test firmware: EG915UEUABR03A06M08_OCPU_QPY_01.300.01.300
Please send me the full local USB .pac firmware package for standard AT firmware, preferably EG915UEUABR03A01M08, and the flashing tool/procedure.
Thank you.
I have sent them to your email,pls check
