Q:I need to use this module in RTK as a base station but the auto survey mode never increse it percentage value.
A:Could you provide all of your configuration detail information to me, i will help you to fix that.
And I suspect maybe this issue because the parameter of 3D_AccLimit of your setting is to high. The module’s fix accuracy not meet the limitation, so the auto mode never increase it percentage value. I recommend you to set this parameter to 3 or 5.
