Firmware for L76-M33
Hello, my name is Khalilov Maksud, and I’m from Kazakhstan.
I purchased an L76-M33 Q1-A7860(firmware L76NR14A01S) GPS module on AliExpress to repair my navigator.
However, after the replacement, the GPS didn’t work. Can you provide the original firmware from the navigator (L76NR02A07S, 2016/04/22)?
Thank you in advance.
halilov.maksud@gmail.com
Hi @mx14
I have send you the latest firmware via email
Please let me know if you have received it
Best regards,
Thank you, but I need the old firmware version (L76NR02A07S), the navigator does not work correctly with the new firmware
Sorry, but the problem is not solved yet.
Hi @mx14
Apologies for the late reply
What is the issue you are currently facing at the moment? Can you provide the NMEA log from the QGNSS tool?
The module itself works, it shows location in QGNSS, everything is fine. There’s a problem with communication between the GPS module and the navigator’s microcontroller. I set the settings the same as the previous module (satellites appear and then immediately disappear). Therefore, I want to try flashing the new module with the old firmware from 2016. I’m using Google Translate, so there may be some inaccuracies.
