I am using gnss module of ec200ucn.. for which i am using the following sequence for getting location:
- Configure gnss after boot one time..
- Get location using qgpsloc
I am sharing my code snippet which is based on esp32 s3..
esp_err_t gsm_gnss_configure_once(void) {
char resp[GSM_MAX_RESPONSE_LEN];
if (!gnss_cfg_done) {
// AGPS server (once)
(void)gsm_send_command_wait_response(
"AT+QAGPSCFG=1,\"http://quectel-api1.rx-networks.cn/rxn-api/locationApi/rtcm\","
"\"wLgWwv6JQt\",\"Quectel\",\"aFltUERDZzZxeTY5cEp2eA==\",1,\"iot.com\"",
"OK", resp, GSM_UART_TIMEOUT_MS);
// Enable AGPS
if (!agps_enabled) {
if (gsm_send_command_wait_response("AT+QAGPS=1", "OK", resp, GSM_UART_TIMEOUT_MS) == ESP_OK) {
agps_enabled = true;
// GNSS config
(void)gsm_send_command_wait_response("AT+QGPSCFG=\"gnssconfig\",5", "OK", resp, GSM_UART_TIMEOUT_MS);
(void)gsm_send_command_wait_response("AT+QGPSCFG=\"gpsnmeatype\",31", "OK", resp, GSM_UART_TIMEOUT_MS);
(void)gsm_send_command_wait_response("AT+QGPSCFG=\"beidounmeatype\",31", "OK", resp, GSM_UART_TIMEOUT_MS);
gnss_cfg_done = true;
ESP_LOGI(TAG, "GNSS one-time configuration finished");
return ESP_OK;
esp_err_t gsm_get_location(gps_data_t *gps_data) {
esp_err_t ret;
char response[GSM_MAX_RESPONSE_LEN];
int retry_count = 2;
// init struct...
memset(gps_data, 0, sizeof(*gps_data));
gps_data->is_valid = false;
// Ensure engine on
ret = gsm_send_command_wait_response("AT+QGPS?", "OK", response, GSM_UART_TIMEOUT_MS);
if (ret != ESP_OK || strstr(response, "+QGPS: 1") == NULL) {
ESP_LOGI(TAG, "Starting GNSS engine…");
ret = gsm_send_command_wait_response("AT+QGPS=1,30,500,0,1", "OK", response, GSM_UART_TIMEOUT_MS);
if (ret != ESP_OK) {
ESP_LOGW(TAG, "Failed to start GNSS engine: %s", response);
return ESP_FAIL;
vTaskDelay(pdMS_TO_TICKS(1000));
while (retry_count-- > 0) {
ret = gsm_send_command_wait_response("AT+QGPSLOC=2", "OK", response, 5000);
if (ret == ESP_OK && strstr(response, "+QGPSLOC:")) {
char *q = strstr(response, "+QGPSLOC:");
if (q && parse_gps_response(q, gps_data) && gps_data->is_valid) {
gps_valid = true;
return ESP_OK;
} else if (ret != ESP_OK || strstr(response, "+CME ERROR: 516")) {
// fallback
(void)gsm_send_command_wait_response("AT+QGPSGNMEA=\"GGA\"", "OK", response, GSM_UART_TIMEOUT_MS);
vTaskDelay(pdMS_TO_TICKS(3000));
gps_valid = false;
return ESP_FAIL;
We have tested on 7 devices.. Only 1 device gave the full location and worked properly.. but in case of other 6 we didn’t get the location.. sometimes we get only 1 or 2 location point but we should get around 500 points for a location tetsing trip..
can someone check the location at command sequence and suggest if some change is needed?
