External Passive Antenna
I am looking to connect external passive antenna to L89HA. I am using successfully external active antenna, but want to test external passive antenna. Should I simply connect passive antenna instead of Active antenna ?
Hi @N_N
The L89HA module comes with a passive antenna.
If an active antenna is connected to the outside, the module will actively identify the active antenna. If the active antenna is not connected, the module will use its own passive antenna.
